20 Most Recent
Abit (WLP-01) Wireless Adapter Questions & Answers
Abit wlp-01 picks up many
I am unsure as to what your question is? Do you want to know how to use the wireless adapter to connect to networks and access the internet? If this is your question, here is my answer;
When the wireless adapter picks up the signal to the network that you wish to access, choose to connect to it. From that point, you need to know the name of the network, the WEP Code or password for the router or network connection and the passphrase or password that allows the user to connect to the network.
Once all the above information is entered, connecting to the network should not be a problem. If you are encountering specific errors or problems, use the comment or reply link on Fixya near your question and report them to me. I will be happy to assist until this problem is solved.
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
your connection won`t drop after this.
Abit wlp-01 suddenly won't find wireless network
With other adapters, I have needed to run a registry cleaner WinASO or RegistryFirstAid to clean out the unused entries so they could be reinstalled properly. Similar to removing some famous brands of Anitvirus that do not completely remove themselves.
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Kds monitors support
Hi Klex,
I was able to find the website address
www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
