20 Most Recent
Philco 841205 Turntable Questions & Answers
Philco 841.205 Turntable Issues
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
Brand new in box..cd will not open
If it is BRAND NEW, obviously it's defective and you shouldn'n mess with it. Return it to the shop where you bought it and claim your warranty. Trying to "repair" it might VOID your warrant!
A few years ago I purchased a Philco capital
maybe the button when being pressed isn't releasing through a bad button . it would make sense that when the button is pushed it stops all functions so if you r able to disconect the button from the wires tape the wires together to create a closed circuit and see if it works personally i would take it to a repair facility for the safety factor of messing around with it but if u want try it
Play records
This indicates to me that either the belt is in the wrong position or that there's something wrong with the drive circuit.
