20 Most Recent Nikon Speedlight SB-22S TTL Flash Questions & Answers
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
2/11/2018 9:54:24 PM • Nikon Speedlight... • Answered on Feb 11, 2018
2answers
Can I use Nikon SB-22s speed light with my Nikon
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
4/14/2015 1:22:40 AM • Nikon Speedlight... • Answered on Apr 14, 2015
CAN I USE A NIKON SB-22S SPEEDLIGHT ON A sony slt a35
If you're worried about the trigger voltage, it's safe according to this list: http://www.botzilla.com/photo/strobeVolts.html.You won't get all of the automation as you would with a flash intended to be used with a Sony camera.
10/26/2013 1:55:43 AM • Nikon Speedlight... • Answered on Oct 26, 2013
Can I use Nikon SB-22s speedlight with my digital
10/26/2013 1:54:25 AM • Nikon Speedlight... • Answered on Oct 26, 2013
Can I use my old
Yes, the trigger voltage is low enough not to harm the camera. However, you will not have all the capabilities of a newer flash.
3/7/2011 5:48:35 PM • Nikon Speedlight... • Answered on Mar 07, 2011
Coolpix 5700 pop up flash
Yo have an internal switch or control unit issue.A switch which is either a solid state controller or a mechanical which has failed which is why you are getting the error message.To DIY this will require a lot of patience and self control for the parts are really delicate or fragile to work with.It will need a camera technician and tools to get work right.And not to mention electric shock when you get near the flash unit area.
1/30/2011 9:02:58 AM • Nikon Speedlight... • Answered on Jan 30, 2011
Flash Nikon SB-22S works with
No--SB-400, SB-600, SB-800, SB-700 or SB-900.
1/26/2011 11:38:08 PM • Nikon Speedlight... • Answered on Jan 26, 2011
Nikon d90 and spidlight sb
this flash will not work on the newer digital nikon cameras, the flash for d90 needs to be ittl compatible.
1/16/2011 4:01:51 PM • Nikon Speedlight... • Answered on Jan 16, 2011
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
5/26/2010 11:29:45 PM • Nikon Speedlight... • Answered on May 26, 2010
CAN I USE A NIKON SB-22S SPEEDLIGHT ON A NIKON D80
Yes, but not all features may work. Look in the manual under "Optional Accessories."
12/29/2009 10:42:32 PM • Nikon Speedlight... • Answered on Dec 29, 2009
Black & White shots from Nikon D80
You would be better off shooting in regular mode and converting to B&W using photoshop
6/14/2009 3:33:36 AM • Nikon Speedlight... • Answered on Jun 14, 2009
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
4/17/2009 7:21:00 PM • Nikon Speedlight... • Answered on Apr 17, 2009
Use of Nikon SB22s as slave flash.
in the manual setting the SB-22s is just a standard flash and should work with a standard hotshoe.
12/23/2008 8:11:21 PM • Nikon Speedlight... • Answered on Dec 23, 2008
Professionnals tools
This flash was made in the 1990's for use on nikon film cameras. It wont work in TTL mode on current nikon models, and it has no infrared remote capability like the sb600/800 speedlights, but it can still be fired in manual mode by even the newest nikon cameras. I wouldnt throw it away, but I probably wouldnt use it that much either.
5/21/2008 12:05:33 AM • Nikon Speedlight... • Answered on May 21, 2008
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
3/27/2024 3:34:09 PM • Nikon Cameras • Answered on Mar 27, 2024
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full. r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining. If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
1/28/2024 3:26:09 PM • Nikon Cameras • Answered on Jan 28, 2024
I'm using a Nikon D3100 with a kit lens & my 55-200mm lens. And most of the time I encounter a problem every time I press the shutter button due to r07?
  • The "r07" message on a Nikon camera typically indicates the number of available shots in the camera buffer. It's not an error but rather an informational message. The number "r07" means that there are seven shots available in the camera buffer before it fills up. This is a normal part of the camera's operation and doesn't necessarily indicate a problem. It's more noticeable when you're shooting in continuous or burst mode. If you experience issues beyond this, it's advisable to check your camera settings and consult the camera manual. https://caranddriver.com/
1/26/2024 11:54:11 AM • Nikon Cameras • Answered on Jan 26, 2024
Nikon Speedlight SB-22S TTL Flash Logo
Popular Tags
20 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
flash nikon sb 22s works
  • Cameras
