20 Most Recent Bower (724AFN) for Nikon Flash Questions & Answers
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
1/7/2009 4:35:56 PM • Bower (724AFN)... • Answered on Jan 07, 2009
Battery pack
If you want guaranteed performance, use original parts only!
Jerry G.
7/9/2008 12:16:59 AM • Bower (724AFN)... • Answered on Jul 09, 2008
Bower 724AFN
You should talk to the Bower tech support or to professional camera place that sells these flashes.
It is possible that the flash is defective, or there is a non compatibility issue.
You have to remember that these technologies use very sophisticated computerized design. It is very easy to have compatibility issues especially when matching devices from one manufacture to the other. There are some industry standards, but it is impossible to have perfection with all the possible protocols between different types of equipment.
Personally, I stay with the same manufacture for all the options, unless the other devices I choose are known to be compatible.
Jerry G.
7/9/2008 12:16:03 AM • Bower (724AFN)... • Answered on Jul 09, 2008
2answers
Need manual
Why need a manual? the lens only can be used in complete manual mode. Once connected to your camera, the f /8 makes it impossible for your camera to focus automatically. Even if there was a focus motor it would not work. And it has only one focal length 500 mm, so there is also nothing to change. Then most cameras won't be able to set the aperture, so you have to set that yourself to. Best way to use this lens is to put your camera in M (manually) and dial in all settings yourself, till you have a good shot.
5/6/2015 2:48:50 PM • Bower Cameras • Answered on May 06, 2015
0answers
0answers
Battery incompatable
Just because someone claims a battery is compatible does not make it so. Nikon knows the specs of their batteries. Third-parties have to reverse-engineer to work out the specs, and they don't always get everything right.Stay with Nikon batteries, unless you want to jeopardize your camera just to save a few dollars.
5/16/2012 6:26:18 PM • Bower Cameras • Answered on May 16, 2012
Digital Harinezumi 2++ won't turn on
It is not well thought of and considered a toy. https://www.google.com/search?q=digital+harinezumi+2+won%27t+turn+on ..
4/20/2024 12:20:14 PM • Cameras • Answered Yesterday
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try: Check Picture Location: Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer. Repair or Reset the Photo App (for Windows 11): Go to Settings > Apps > Photo. Click on Advanced options. Choose either Repair or Reset to address any potential issues with the Photo app. Enable Thumbnail Previews (for Windows 10): Open File Explorer Options: Type "file explorer options" in the Windows search bar and select the first result. Switch to the View tab. Ensure that the option "Always show icons, never thumbnails" is unchecked. Click Apply and then OK to save the changes. That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM • Cameras • Answered 2 days ago
2answers
I forgot the combination to my safe can i reset it
limited info generic answer notify manufacturer or locksmith for assistance
4/16/2024 7:20:17 PM • Cameras • Answered on Apr 16, 2024
Activition code digital tv 2050
Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
4/15/2024 9:02:35 PM • Cameras • Answered on Apr 15, 2024
INTERNAL ERROR FREEGROMRIGHT SIZE 1431655766
I don't see anything that resembles 'make model (what it is)'. You posted to the category Cameras? https://www.google.com/search?q=FREEGROMRIGHT+SIZE+1431655766 ..
4/5/2024 1:31:05 AM • Cameras • Answered on Apr 05, 2024
2answers
Where can I get Manual for novar ed&s wireless colour camera
if you purchased the camera from a retailer or reseller, they may have a copy of the manual available.
4/4/2024 12:04:13 AM • Cameras • Answered on Apr 04, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps: Connect to Your PC: Connect the standard USB cable (supplied) to a free USB socket on your PC. The end of the USB cable should be connected to the socket on the back of the USB digidock. Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation. Install DigiConnect Windows® Software: Insert your Digivue into the docking station. If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue. Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear. If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe. If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next." Accept the terms in the License Agreement and proceed with the installation. Choose the folder for software installation (default is the standard location for Windows® programs). Click "Install" to begin the installation. Leave the box labeled "Launch DigiConnect" ticked and click "Finish." Wait for the Red LED: Wait until a RED LED appears in the activity window of the Digivue. You may now proceed with the next steps. If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM • Cameras • Answered on Apr 01, 2024
Hello, I would like to know how to solve an error called "ALLARME" "sicur camera"??
Reboot everything. If that doesn't work, Maker Support.
SICUR SERVICE ITALIA
SICUR SERVICE ITALIA https://www.sicurserviceitalia.it ·Translate this page 1.3 MP Camera · 2 Mega Pixel Camera · 3 Mega Pixel Camera · 4 Mega Pixel IR Camera · 5 Mega Pixel IR Camera · 12 Mega Pixel Camera · Speed Dome da esterno ... ..
3/15/2024 2:12:47 PM • Cameras • Answered on Mar 15, 2024
2answers
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in Ernakulam, Kerala:
  1. Maks Wedding Photography:
    • Located inChelad, Kothamangalam, Kerala.
    • Specializes inwedding photography and videography.
    • Contact:099478 23133.
    • Facebook Page
  2. Lumiere Wedding Company:
    • Based in Ernakulam, Kerala.
    • Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
    • They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
    • Contact:099951 48014.
    • Website
  3. Euforia Wedding Photography:
    • Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
    • Offers candid and artful wedding photography packages.
    • Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
    • Contact:090481 90403.
    • Website
  4. Dakshin Wedding Services:
    • Exclusive wedding photography and videography company covering events across South India.
    • Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
    • Contact:070123 90551.
    • More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM • Cameras • Answered on Mar 15, 2024
Hi, I am in Dubai,I
FUJIFILM MIDDLE EAST FZE [Subsidiary] Business Field (s): Digital Cameras
Address: P.O. Box 17212, R/A08, HB03, Jebel Ali, Dubai, U.A.E.
Tel: 971-4-883-9990
GRAND STORES [Distributor] Business Field (s): Photographic Film and Paper, Film Cameras, Digital Cameras, Digital Printers, Minilab Systems, Medical Systems
Address: Saleh Mohammed Bin, Lahej Building, Al Garhood, P.O. Box 2144, Deira, Dubai, U.A.E.
Tel: 971-4-2-823700
Dynagraph For Printing Industry [Distributor] Business Field (s): Graphic Systems
Address: Al Quoz Industrial Area, Sultan Al Suwaidi Building, Office No.1, Dubai, U.A.E.
Website:
3/14/2024 5:17:47 AM • Cameras • Answered on Mar 14, 2024
Hi, Have replaced batteries on model Gardenline brand model46715 garden timer and there is no digital screen showing on the timer. It is blank, like it needs new batteries.Can you please help me? Russ
Here are some steps you can take to diagnose and potentially resolve the problem: Check Battery Polarity: Ensure that the batteries are inserted correctly, with the positive (+) and negative (-) terminals aligned properly. Sometimes a simple reversal of the batteries can cause display issues. Reset the Timer: Some electronic devices benefit from a reset. Try removing the batteries, waiting for a minute, and then reinserting them. This action might reset the timer and bring the display back to life. Inspect the Battery Compartment: Look for any signs of corrosion or dirt in the battery compartment. Clean it gently using a cotton swab or a soft cloth. Corrosion can disrupt the electrical connection and affect the display. Test with Fresh Batteries: Even if the batteries are new, they might be defective. Try using a different set of fresh batteries to see if the display turns on. Check for a Backlight or Contrast Setting: Some timers have adjustable backlight or contrast settings. If your model has this feature, try adjusting it to see if the display becomes visible. Contact Customer Support: If none of the above steps work, consider reaching out to the manufacturer's customer support. Remember that the Gardenline brand model 46715 has received mixed reviews, with some users reporting issues related to the LCD screen. While some have had positive experiences, others have encountered problems like fading screens or dead displays . If none of this works, you may need to explore another timer.
3/13/2024 2:39:50 AM • Cameras • Answered on Mar 13, 2024
What type of battery does my TVG it has two batteries
All question need 'make model (what it is) as first 3 words or this happens https://www.google.com/search?q=What+type+of+battery+does+my+TVG+have Guessing is is a mobility scooter, but even so. Google know all the answers, your search query would be make model battery replacement Or just look at what is one the existing ones if you have them. Or Google make model manual Everything is online and my skill is finding stuff. ..
3/13/2024 2:19:59 AM • Cameras • Answered on Mar 13, 2024
Bower (724AFN) for Nikon Flash Logo
6 questions posted
Top Bower Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Bower Camera Expert? Answer questions, earn points and help others
View Most Popular
Bower Cameras
  • Bower Cameras
Most Popular Question
nikon d80 using bower af 724afn
  • Cameras
