20 Most Recent Philips 60PL9200D Projection Televisions Questions & Answers
Television won't turn on but the light is blinking
Count the # and sequence of blinks, that is your error code, contact Philips tech support, they will give you a idea of what is the problem
2/6/2014 6:59:26 AM • Philips... • Answered on Feb 06, 2014
0answers
No color
Be the first to answer 1/6/2014 7:15:05 AM • Philips... • Posted on Jan 06, 2014Be the first to answer
0answers
65 error code
Be the first to answer 10/11/2013 2:34:35 AM • Philips... • Posted on Oct 11, 2013Be the first to answer
2answers
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
9/17/2013 9:33:28 PM • Philips... • Answered on Sep 17, 2013
Philips tv 60PL9200D/37 picture getting dark
Below are two of the most common problems encountered with projection TV sets. Problem #1 - CONVERGENCE PROBLEMProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on Projection TV sets and a fairly simple DIY fix.Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.1d5e2cf.jpgff5b9f6.jpg7deade1.jpgHere is a quick test....Using your original remote go-to the settings menu then goto the convergence section.Try to adjust the red and then the blue convergence.You should be able to move RED and BLUE in all directions - up, down, left, and right.If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution47a7bc4.pngCONVERGENCE SOLUTIONYou will need to replace the convergence chips and possibly some convergence resistors and pico fuses. This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.comTheir kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc. Problem #2 CRT Fluid is CloudyProjection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video. Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc. BEFORE7c190d8.jpgSet after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again. AFTERa798d23.jpg724bcba.pngSolution #2 - CRT FLUID FIXWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
4/19/2013 6:59:10 PM • Philips... • Answered on Apr 19, 2013
No picture but i have sound. flashing blue light. i took back off lamp is working what can i look for now?
How do you know the lamp is working:?
4/19/2013 6:57:36 PM • Philips... • Answered on Apr 19, 2013
Which fan do I need to buy to replace in my 60pl9200d/37
Lamp fans fail most often from the heat---good luck getting one with no idea of which you want---Philips not known for being real helpful to consumers.What is set doing or not?
11/6/2012 4:10:33 PM • Philips... • Answered on Nov 06, 2012
Buzzing noise from within the 60PL9200D/37 TV
it is your color wheel
10/3/2012 8:05:19 PM • Philips... • Answered on Oct 03, 2012
Need to know how to fix a blurry screen
be very careful if cleaning the screen---any chemical can destroy the coating on the outside of it.Usually just a lens cloth and or a damp soft cloth are used.Try lens cloth first.
6/14/2012 6:11:30 PM • Philips... • Answered on Jun 14, 2012
Ballast board
If you contact the mfr or GOOGLE THE MODEL NUMBER WITH BALLAST AFTER IT you should be able to locate a part number and or someone selling it.
3/20/2012 2:34:03 AM • Philips... • Answered on Mar 20, 2012
0answers
Issue with my philips dlp
I now have the same issue. Did you ever solve your problem? Did you find the ballast ? Where ?
11/20/2011 1:18:20 PM • Philips... • Answered on Nov 20, 2011
I have a Philips dlp60pl...the picture flickers
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
9/24/2011 5:52:46 AM • Philips... • Answered on Sep 24, 2011
2answers
How to replace the bulb in PHilips tv model
my tv flashes 6 times slow,pause,5 times fast but it dont power on
8/17/2011 12:35:52 AM • Philips... • Answered on Aug 17, 2011
Philips 60PL9200D Projection Televisions Logo
Popular Tags
83 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 60pl9200d 37 two red lights
  • Televison & Video
