20 Most Recent
Jamo A 102 HCS 5 System Questions & Answers
I've had this system for
Have you proven it is a problem across the board or was it just that particular source/movie that lacked punch? What about your speaker calibration? Check it.
Jamo i300 dies after powercut
If its out of warranty you might as well open it up , and if your lucky it might only be a fuse to replace , if it is fused inside it will probably have blown before it could do any damage to circiuts . hope this helps
I need to power-cycle the
This speaker system is described as consisting of "passive" satellite speakers with an "active" subwoofer. Passive means they require an external amplifier to work - and conversely active means there is a built in amplifier. To "power cycle the board" simply disconnect the power cord for a couple minutes (allows capacitors in the circuit to discharge) and plug back in. That's it.
Jamo i300 speakers are dead.
There is peobably a fuse located on the back. Your speaekers are probably okay. If anything fried inside, it is probably the output transistors.
Jamo subwoofer issues
hai iam hans i had also a problem with the sub
turned out jamo denmark didnt had the spare parts to fix it?
can u believe that
so i wait 6 weeks and after 100 phone calls to denmark and my local dealer they deside to take the part out of another sub ?.
but i really had to make a a lot of effort to achive this
but for the price the jamo set is exellent
a shame about the service .
Jamo sub 660 wont come on
Hi,I have the Jamo sub 660 and it won't come on,I took it to my technician,and he told me that it has a broken ic,the broblem is that he cannot replace it cause the number on it is scratched,does anyone know what the number is pls! Thanks in advance Joseph
Pls help my jamo 210 sub does not swich on, where do i find the fuse
The manual doesn’t show a user replaceable fuse are you plugged into a house outlet or a power strip. If power strip confirm that power is present and try another slot to plug into. https://bcc2479de3c817356f4e-1bbe459354cb22c942d9efbc3d6dacbf.ssl.cf2.rackcdn.com/product-manuals/SUB210_OM.pdf
