20 Most Recent
Sony RDR-GX355 Questions & Answers
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Can I return default back to DVD 3 from DVD
In the operator's manual there are directions to the setup screen. You can select the set up menu and go item by item makign the choices you want. The manual is uploaded here on Fixya or on line through the Sony web site.
I have an RDRGX355 and
So the "mute" is off, and you're sure you've selected the right settings on the TV and/or the amplifier you're using with the DVD player?
I cant get my Sony RDR-GX355 to record, I only get
A blank DVD means the write laser is not working correctly.
A quick check: write on a disc that has something you don't want ALREADY ON IT. If the disc comes out blank, the write laser is on but not focused. If the disk still works, the write laser is not on or very weak. Either way, it likely means a new laser assembly + alignment.
Can not record. When I
If you are recording from a digital video camera you should be using the DV-IN jack(that's why you get the dv/d8 error). If you are just trying to record a show from a cablr/sat channel then you need to select the correct input for the device you are trying to record from(vid1,vid2,dvin etc). you can download a service mnaual from sony.com if you are in need of one.
GX355 won't power up. HDMI
Usually this is a Problem that needs Disassembling. First of ALL, unplug he Unit for Few Minutes. Make sure all the Output/Input Devices are Unplugged. Turn it Back ON. ( Say 15 Minutes ). If it still does not Respond, you need to Open the Player.
Note - This Might Void the Warranty, if any. Only Perform if you are Good at Electronics.
http://www.maxim-ic.com/appnotes.cfm/an_pk/2947
Read the above Link.
The power circuit for the DVD and the VCR are separate look for a open diode and transistor in the circuit that supply the DVD. Once you open it, also Check for the Fuse to make sure it was not Blown.
Download the Service Manual from :-
http://nodevice.in/manual/sonymans/manual4241pdf/get5756.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
I CAN'T GET MY REMOTE TO WORK AFTER SELECTING dvd1
I finally got it fixed . I press the number one and enter key for about 5 seconds on the remote while I had the DVD player on and TV the
I press 1 again for 5 seconds and then press menu key till the menu
display on TV screen then I was able to change the settings back from DVD1 to DVD3. The DVD player now works fine
