20 Most Recent Amana NAV2330AW Top Load Washer Questions & Answers
Spinning slow and smells like burnt rubber. Draining very slowly.
Pull drain plug at bottom of machine put tray under it check belt
12/18/2017 2:05:50 PM • Amana NAV2330AW... • Answered on Dec 18, 2017
My top loader washer will not drain the water
Washer will not drain: Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement. Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed. Go to Google or YouTube and search for " If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
4/11/2015 9:15:04 PM • Amana NAV2330AW... • Answered on Apr 11, 2015
0answers
0answers
0answers
Repair
Be the first to answer 7/8/2013 3:37:05 PM • Amana NAV2330AW... • Posted on Jul 08, 2013Be the first to answer
Amana nav2330aww leaking. just replaced the pump, not it. water coming from between bottom of tub and
Your problem is the tub seal has failed and will need to be replaced.Here is a link to the kit you will need.
10/14/2012 8:15:40 PM • Amana NAV2330AW... • Answered on Oct 14, 2012
Amana NAV2330AW Top Load Washer Logo
45 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
amana nav2330aww leaking just replaced
  • Washing Machines
