20 Most Recent Ecoquest Breeze AT Living Air Purifier Questions & Answers
2answers
Shortly after I turn on the sanitizer on the
Remove the plaques and using an old tooth brush clean with mild soap and water.. Rinse thoroughly, towel dry and finish drying them with blow drier. The interior of the unit and it's filter should also be cleaned. Depending on what type filer it uses (Aluminum mesh or soft mesh plastic) they too and can be washed with mild soap and water, rinsed and thoroughly dried. Any other type filter material may need to be replaced. Clean the interior with canned compressed air with a straw nozzle and a dry paper towel.
Of course, before you do any of the above, unplug the unit.
5/30/2020 6:32:02 PM • Ecoquest Breeze... • Answered on May 30, 2020
Need to replace fan blade. doi just the other blade off or do i need a tool
You should be able to get the fan off w/ a small screwdriver & some needle nose pliers for the metal clamp that holds the fan onto the shaft. Look on Google for suppliers to get a new fan & clamp. It shouldn't be expensive.
5/11/2014 8:30:17 PM • Ecoquest Breeze... • Answered on May 11, 2014
0answers
Rust
Be the first to answer 3/23/2014 4:40:05 AM • Ecoquest Breeze... • Posted on Mar 23, 2014Be the first to answer
IQair healthpro, change fuse, where to locate and
check on youtube.
11/29/2013 12:27:14 PM • Ecoquest Breeze... • Answered on Nov 29, 2013
Will not turn on - no power at all
If your Breeze was working, but you cleaned it and now it won't turn on, the problem almost certainly is with the reassembly of the components. Go through the following checklist. 1) Make sure the plug in the back is inserted firmly and the wall socket is live. 2) The little switch by the plug should have the "I" end depressed and the "0" end up. 3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly). 4) Make sure the plates are inserted correctly, with the top and bottom in the little grooves and the metal fingers pressing firmly on the screen part of the plate. You may need to twist the white upright posts slightly to align the contacts. 5) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote. If one set of controls works, but the other doesn't, you may operate the machine with only the working controls and ignore the others. 6) If none of the above suggestions helps, remove the plug in back, and pull out the fuse to see if it is blown. Very infrequently, a sudden powerup or power surge will blow the fuse. If so, replace it with the EXACT same size fuse, available at an auto parts store.If none of these troubleshooting steps works, then it would appear that the problem is in the computerization. Unfortunately, Vollara (new name for EcoQuest) is no longer servicing nor selling the Breeze. Your only option to get it fixed would be to find a dealer who still has some, along with extra parts, in stock. If you call Customer Service, they will give you some trade-up options. 800-989-2299. Use #16618 if you need a referral number.
9/22/2013 7:06:20 PM • Ecoquest Breeze... • Answered on Sep 22, 2013
2answers
The Breeze AT will not stay on
filter in back may need cleaned
7/28/2012 11:39:00 PM • Ecoquest Breeze... • Answered on Jul 28, 2012
2answers
I need to clean my Eco Quest Living Air purifyer plate...
clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
4/16/2012 12:59:36 AM • Ecoquest Breeze... • Answered on Apr 16, 2012
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
9/14/2011 3:19:21 AM • Ecoquest Breeze... • Answered on Sep 14, 2011
Ecoquest Breeze AT Living Air Purifier Logo
230 questions posted
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Ecoquest Air Purifiers
Most Popular Question
clean
  • Air Purifiers
