20 Most Recent
Akai PT50DL24 Television Questions & Answers
HELP!!!
I think i have the solution to your problem,
I think that the lamp has gone out in your tv. You should try changing it out. I work with many tv's with DLP's and it almost always is the lamp. YOu can order it online, there is a slot on the side of the tv were you can change it out through there, the lamp should have a number on it. And its pretty simple to do. So there you go..and I could have gotten you a better deal on your Tv.
THE END
Bad fan
di you replace the ballest that power up the lamp
Akai tv no sound and no picture
Try to confirm if it has power supply,from the ac power plug up to the power supply components,,Maybe a qualified person can do so...Dods
We recently adopted a Akai
Tv have a word "LAMP" on it front face frame bazel?Yes,than this tv model have a projection lamp it is dying requirement of the projection lamp replacement.Tv can be save.Not no "LAMP" word on it the front bazel frame.Not repairable,because it is using CRTS-tv tubes tech.Sorry it is garbage tv time,those CRTS tubes are dying,not worth replacing and cost almost the same as a new tv itself,if u can buy it refurbish CRTS tubes anymore all.
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Picture seems dim, brightness at
how long have you been using this TV and have you ever changed the TV bulb since you have been using it?
It's seems the bulb of your TV needs replacement for your picture to be bright again. This problem is a symptom of a weak bulb.
Turn off the TV, wait for about 10mins, get a screw driver, open the TV back cover and you will find the TV bulb at the back of the tube. Unscrew the bulb and replace it with another.
Note that you are asked to wait for about 10mins before opening the TV back cover because TV stores current even after it is turned off.
Good luck.
My rear projection TV seems
Sorry it is not that simple. The problem you have specified indicates multiple problems with the tuner circuit. It is not possible to test this without special equipment(to compute waveforms). Replacing the board is the most cost-effective solution.
Sai.
FAN MAKES LOUD NOISE
most likely you need to clean it from dust.
it is easy to do:
1. unplug the power cord from the socket
2. unplug the power cord from the computer
3. un-screw the screws that holds the cover of the computer
4. clean all the fans- best by blowing air at them
5.close the cover along with the screws.
I put in a new
You may have to call AKAI to get some kind of diagram. If they are identical cables though I think it may just be power cables and they can go into either slot and work the same in both.
Thanks
Tim
When turning on the Akai
Hi and welcome to the site,
Initially, any other indications such as a blinking light?
Good luck and thank you for asking.
