20 Most Recent Miele Optima G2430SCi Stainless Steel Built-in Dishwasher Questions & Answers
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Miele Optima... | Answered on Mar 11, 2018
More information maybe needed...
Is this a new install or existing? (if existing please repost with more details of how this came to be)
If new install, the drain is not properly installed - Make certain you have a loop of hose on the outside of the dishwasher, typically it is on the unit and factory installed and attached,. if the loop is changed then you will not have drainage and it would trigger a problem with the intake/ drain,,,
Best regards
Ck
Miele Optima... | Answered on Mar 09, 2011
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required.
If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Miele Optima... | Answered on Jan 28, 2011
Hi Jennyglopez..I do not think your pump is the issue,however you can make this checks.1-Take the filter combination out of the wash cabinet 2-Scoop the water out of the cabinet using a suitable container 3-Press the catch for the non-return valve inwards 4-Lift out the non-return valve and rinse well under running water.5-Remove all foreign objects from then on-return valve and drain pump 6-Carefully replace the non-return valve and secure it with the catch.Ensure that the catch engages correctly.You can also check drain hose &remove any kink in the drainhose.where the drain hose engages under the sink sometime gets clogged.Disengage the pipe & make sure hole in the drainage not clogged.Thanks & goodluck
Miele Optima... | Answered on Aug 25, 2010
top spray arm clogged remove and clean.adrian,,,,,
Miele Optima... | Answered on Jul 15, 2010
If this happens at the very start then the unit is not draining properly.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Miele Optima... | Answered on Jan 25, 2010
if you have been using the dishwasher on fast wash programs for a long time this can cause build up in the sump area causing unpleasant odors recommend running a good quality cleaner trough this will freshen it up also use higher temperature washes more regularly let me know the outcome
Miele Optima... | Answered on Nov 12, 2009
Hello Zipmap0202,
I have never found that plastic dries very well in my Miele dishwasher as well.
Check your rinse aid indicator to see if it is on. Next to the soap door there is a door you can add rinse aid to. There is also a dispensing control knob that allows you to turn the amount of rinse aid dispensed up or down. Try changing the setting and see how that works. I have done this and it has not worked well for me. I find opening the door after the cycle is done (Just cracking) it will dry plastic alot better
Miele Optima... | Answered on Sep 16, 2009
The display shows P and the digit/s of the set value alternately. Setting range: P0 = Sensor Softener active. P1 to P70 = Water hardness,
you have to set the water hardness of the dishwasher
Miele Optima... | Answered on Jun 23, 2009
NO IDEA HERE TRY LOCAL REPAIR SERVICE
Miele... | Answered on Jan 22, 2020
Miele Optima G2430SCi Stainless Steel Built-in Dishwasher Logo
27 questions posted
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Miele Dishwashers
  • Miele Dishwashers
Most Popular Question
intake light flashes start cleaned
  • Dishwashers
