20 Most Recent
Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop Questions & Answers
Power button problem
Without being there to troubleshoot further, the first thing I'd recommend is checking the breaker. It'll most likely be in the breaker panel outside the house... in the BIG panel. This is a 240 Volt unit, so what you'll be looking for is a "dual" breaker. They'll be connected together.
I'll tell you what... here's the easy way to do it. Simply turn off, then turn on all the breakers in the big breaker box outside. Make sure you have all the computers turned off first, though. You might have to reset a few clocks, but that's OK. I'd bet this gets you cooking again. If not, post back.
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
I have an induction cooktop
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
What does the 'E73' error
1. Make sure that you have placed a metal container on the device which is compatible with the Induction cooker.
2. Try reseting the breaker, the instruction are available in the user manual.
Try these. I will be there to help you!
