so for some reason the
needles never seem to look broken But a tiny chip on them will make the player do exactly what your describing, as far as the counter weights,, spin the player by hand , click the handle to make the arm begin to position itself at the beginning of the record, Now, before it drops, slow down the hand spinning, and set the weight so that when the arm is supposed to drop it doesn't,, in other words balance it to be level, No up or down motion, without a weight scale to do this by the book, try this , Its always worked for me, tape 2 pennies to the weight at the rear of the arm, and one penny to the head of the arm, again, adjust it to be level,, then remove all the pennies,, the arm will have about the correct weight they require for the needle to be correct,, if it still slides, you have a bad needle
