20 Most Recent
Dell WL6000 Computer Speakers Questions & Answers
I have been experiencing static
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
My front left and right
Just go to any electronics store with the part and they will identify for the part. Could be a simple RCA connector.
Lot of noise make
Seems it is getting bad when speaker heats upAudio out ic may be partially defectiveCant say exactly the reason without checkingNeed to check individual componentTry to investigatethx
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at
http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Just got a wireless modem from telstra. now the
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
hope this helps you
My rear speakers are not
Here is a guide to the sounds on a computer
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Help! Kids "blew" the
There's no way back from there, that would be permanent damage. (Just make sure that the cable is fully plugged in as well).
Repair is possible by swapping the drivers (and carefully soldering them in) but to be honest, it probably isn't worth it. If it's within warranty, I'd try sending it back under warranty. Otherwise, start shopping around.
I had sound last night
This problem actually happened to me. A lot of people have this same problem and find that downloading the appropriate sound or audio controller fixes the problem. You can do this by searching for 'Dell WL6000 sound driver downlaod' or 'Dell WL6000 audio controller download'. This should fic the problem. However, for me, is did not. So I did a bit of reasearch on the internet, and found that actually, there is no way of restoring sound on the computer; not even re-installing windows, or a new windows package. I tried this, but it didn't work. This is becazuse once the sound is gonefrom the computer, it is permanantly gone. What you have to do, is purchase a new sound card.
Hope that helps,
pennywise25.
