20 Most Recent
Black & Decker SpaceMaker ODC440B 12-Cup Coffee Maker Questions & Answers
We have a Black and
Use your phone book or online yellow pages to search for a repair shop in your area. I suspect a thermal fuse has blown in your unit. Only an experienced repair tech can replace it. Sometimes, the cost of the repair is more than a replacement appliance.
There is no power to the unit
the thermal fuse has blown.
be careful after replacing it because the reason it blew is probably because the unit overheated which means the thermal switch failed (stayed closed)
My Black and Decker Spacemaker coffee Maker will
We had this same problem and it turned out that the inside if display and circuit board caught on fire and melted inside. File a report with the USCPSC and call Black and Decker. They are sending us a new model free of charge but they are also telling me to send them the coffee pot free of charge wtih postage paid. I refuse to do this for 30 days because the Consumer Product safety commission wants me to keep it for 30 days to investigate
I have black & decker pw1400s it is possible to connect the water faucet
It will depend on what kind of faucet it is. You can get adapters for the faucet on your kitchen sink but I find they are not very good for pressure washers. They can leak and spray water all over your sink and kitchen. For a pressure washer it is best to have an outside faucet fitted. This will give you the correct type of faucet to connect to and a good supply of water to the pressure washer.
It is usually not very expensive to get one fitted.
Black & Decker CM1609 keeps shutting off in the middle of making coffee
I had my black& Decker for about 6 months or so and it started shutting off after a minute or two of brewing. I cleaned it by running 5 cups white vinagar through it twice and using a filter in basket. Then running 2 pots of clean water through. I had to keep turning it on but by they end of later last pot of water rinse it stay on all they way through .there was an incredible about of lime built up . try it worked for me.
