20 Most Recent Nespresso Essenza C100 Espresso Machine/Coffee Maker Questions & Answers
Nespresso no power
hi you should be able to relocate 2 thermal safety on the boiler check these two with continuity meter start here first if all is well get back to me
1/12/2021 10:50:38 AM • Nespresso... • Answered on Jan 12, 2021
2answers
Small and large cup lights won't stop flashing
Tish3030 response worked PERFECTLY. Thank you, Tish.
12/25/2019 9:42:03 AM • Nespresso... • Answered on Dec 25, 2019
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
3/16/2018 6:24:22 AM • Nespresso... • Answered on Mar 16, 2018
Does anyone know how to pull apart a Nespresso coffee maker ?
Most expresso coffee makers can be taken apart manually. Start removing screws, nuts, etc. Take a picture every so often so you know how to put it back together. See the DeLonghi website to get eerie product manuals. (delonghi.com). Search harder for repair parts and you often can get the sequence of how the parts assemble. You are right, cleaning the jets is the biggest problem area.
1/23/2018 6:01:07 AM • Nespresso... • Answered on Jan 23, 2018
0answers
0answers
2answers
Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
11/22/2016 3:26:11 PM • Nespresso... • Answered on Nov 22, 2016
2answers
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
1/4/2016 10:07:49 AM • Nespresso... • Answered on Jan 04, 2016
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
11/24/2014 3:47:16 AM • Nespresso... • Answered on Nov 24, 2014
2answers
Will not dispense the water into the cup when the
I have had this issue. First, check to make sure water tank is filled and correctly in place? Try descaling it; a kit came with coffee maker. (It just removes hard water build up, it may be blocking your water flow.) If that is not the issue, pull the tray where the used pods are dropped -Is it wet? Like the coffee is pouring into this tray rather than in your cup? If so, I have removed round silver plastic piece from around coffee spout,(gentle -do not crack it) then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! If the POD tray is not wet, I would tell you not that most likely your machine is not clogged by grounds, so you may not want to take snout apart. I hope this helps.
11/23/2014 8:09:24 AM • Nespresso... • Answered on Nov 23, 2014
0answers
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
162 questions posted
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Nespresso Coffee Makers & Espresso...
  • Nespresso Coffee Makers & Espresso...
Most Popular Question
get replacement parts nespresso c100
  • Coffee Makers & Espresso Machines
