20 Most Recent
Breville 800CPXL Juicer Questions & Answers
Bought a new Breville Citrus
Please check the following:
1. Make sure that the JUICE JUG is locked. Once it's not locked, it would not work.
2. Check the sticker on the juicer and verify the voltage that the juicer could receive. Based on the user manual that I have, it should be plugged in to 230/240V power. BUT AGAIN, please check the sticker first to see the voltage input.
3. Try plugging the cord into another power socket. Avoid using stripper and turn it ON.
Please let me know if you have additional information. Hope this helps and have a great day!
Error message
I fixed my juicer that had this problem, the problem was the thermal fuse which is located directly on the motor with some plastic covering it. You can replace the fuse or do what I did and just cut off the fuse and attach the two wires together (no more fuse) and my machine now works again :)
I tried to turn on
there is inside a thermal fuse and it could have blown if wet, can be replace it is 1/8 x 1/2 " long .inside the machine turns off everything when blown , and purchased @ Radio Shack for about $ 5-8 dlrs rated @ 8-10 amps , need more info , if this works for you >
Motor burn out
to clarify- I was just starting out this morning, juicing some carrots and heard a pop (carrot chunk hitting the inside of the pulp cover) and the machine stalled.
