20 Most Recent
Bosch Axxis WFL2090UC Questions & Answers
Hi
I'm after a manual for
This not the full ENr number required to get the instruction manual. Most NEFF hobs ENrs start with a T...Once you've found the number (should be on the base of the hob, which will mean removing drawers or possibly an oven to check) use the link
http://www.neffcustomerservice.co.uk/go to the bottom left of the page and click on 'instruction manual download' this will open another page where you can enter the Enr and then get the user manual. either to store on the computer as a PDF file or to print off.Hope this helps.Roni
Machine seems to fill with
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.If drain hose is checked ok then its confirmed problem of faulty water fill valve.
the fill valve is leaking. When they go bad they can leak water without being told to by the timer. I would replace the fill valve after pulling the hose off the fill end and watching to see if water drips out.
For getting parts you can get it from www.repairclinic.com
Thanks. Keep updated for
any more query. You can rate this solution and show your appreciation.
Our Bosch Axxis Model WFL2090UC/11 is not
yes there should be a water level sensor on it,it either is a small one surface mounted onto a board/timer or seperate,if its seperate you can usually blow into them and here a click or double or treble click depending on the amount of levels on the machine,you can double check switch with a multimeter when you blow into switch,with the switch removed of course.If it spins and washes ok its probably the timer.You can check spinning by dropping hose at spin on timer.
Will fill and pump out drum does not go
replace the motor they are not normally repaired.
does the motor turn when the belt is not attached make sure to check the power from the main control board to the motor.
Stoped rotating
Try to unplug your washing machine and open the lid.
If you can move drum with your hand and if it is free then programator is bad, and if you can not move it with your hand probably cause is broken transmission.
We have a WFL 2090 UC Bosch Axxis Front end load
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Bosch lr30 receiver not turning on
Potential causes and fixes:
Battery Terminal Corrosion:
Cause: If your Bosch laser receiver has been submerged in water, the battery contacts and sometimes the circuit board may have corroded.
Fix:
Remove the batteries and clean the battery terminal contacts.
Pry open the bottom cover and clean any corrosion on the circuit board.
Calibration Issues (for Bosch GLL 2-20):
Cause: Dropping the Bosch GLL 2-20 can lead to misalignment and errors.
Fix:
The best way to address this problem is to calibrate the laser level.
You can either contact the Bosch service center or follow the calibration instructions in the manual.
General steps for calibrating a laser level with a misaligned pendulum:
Remove the screws and outer cover.
Locate the pendulum hanging in its stationary position.
Remove the glass window of the laser level.
Adjust the stationary position of the hanging pendulum using the main adjustment screw.
Fine-tune right-left adjustments using other smaller adjustment screws.
Reassemble the laser level.
Cracked Glass Lens (for Bosch GLL 2-50):
Cause: If the horizontal glass lens is cracked, it affects accuracy and safety.
Fix:
Unfortunately, this problem is often unrepairable.
It's advisable to replace the laser level to ensure safe operation1.
Remember to lock your laser level when not in use or during transportation to prevent pendulum movement1. If these steps don't resolve the issue, consider reaching out to Bosch for professional assistance or repair
