20 Most Recent
Marantz SR5001 Questions & Answers
I have a marantz sr5001 and it displays check dsp rom
On the Marantz SR5001 if you get the "CHECK DSP ROM" it can be fixed by holding down the Multi and ATT buttons at the same time for 3 seconds. This will default any setting so be sure to know the correct input setting for your setup.
I'm looking to connect a Marantz SR5001 to a Subwoofer, and there is currently no soundcoming through the sub.
On the SR series, you should find the setting for this in the setup menu on your remote. It will be easiest if you have a TV connected for video display. On the remote hit Amp -> Menu -> Speaker Setup -> Manual Setup. This should allow you to set the 'Subwoofer' setting to Yes. The subwoofer will need to be plugged in. If the setting cant be changed, try plugging in the Audassey microphone and run the calibration program which should detect the sub if its plugged in.
