20 Most Recent
Sansui D 27" TV275 TV Questions & Answers
Is a Sansui DFTV275 an HD TV?
Is it possible that you typed the model # wrong? I can't find anything for that midel. If it has a hdmi port chances are it is 720p which would be hdtv. If not then it is most likely a standard 480p t.v.
Password
Try these codes first. These are the common codes used to bypass the password. If you get succeed, after getting the TV to ON, reset it with an other password of yours' before switch it OFF. 6668.0000.6868,0101. For more information go to
Remote code codes
0039,0031,0033,0030. Try these codes. For more information check this link. Setup procedure, and
setup code list to many popular remote controls are given. Pull up older posts.
HOW TO UNLOCK CHILDLOCK?
I am not sure if this solution will work, but I posted the manual for these TV's.
If you call their toll free number during a weekday they may be able to help you get it fixed.
Good luck,
Tom
When I switch tv on
Replace , front panel switches , one or more switches goes high resistancewhen suppose to be open circuit , my sv2918 74cm was doing weird thingswith these switches going bad
No pucture but sound
welcome to fixya
its mostly Sounds
like you have lost video somewhere in the video circuits. Possibility is that the
picture tube could have gone bad or lost filament voltage.
You can
check to see if you have high voltage by holding your bare arm close to
the screen. The hairs will stand up if you have high voltage. Absence of
high voltage will also cause a black screen,but the sound might not
work either since on some sets the power for the sound is supplied from
the same circuit as the high voltage.
Try
a hard restart, which simply means unplugging the power cord of the TV,
and replugging it after 4 hours have passed. This technique reprograms
the electronics, to a certain extent. If the picture does not return,
then you have a more serious problem
do comment if it does or it doesn't help you ! we will try to help !
Hi, Could you please advise how can I fix my t.v.
Hello
The memory IC of your TV has damaged. It can be located very near to the main system control IC, an eight terminal one, can be desolder out from the boar very easly. Its number is more important when replacing it. There is no tuning lock occurs with your TV; and the reason is damged memory IC. OK.
Are there any universal remotes
Hello
Select one [One For All URC - 3021, universal remote control. Sansui is lited in its codes. You will get its catelogue and user manual which contains all proceedings about how to setup with it your Sansui TV.
The code for Sansui is
[0463]
OK.
