20 Most Recent
Farberware FAC900R Toaster Oven with Convection Cooking Questions & Answers
Need to activater self-clean
Every
self-cleaning oven is different. It's best to consult the owner's
manual for the correct procedure for your oven. But often the steps
are:
- Set the Start time for the time you want the cleaning to begin.
- Set the Stop time to a time 2-3 hours after the start time.
- Close and latch the oven door.
- Set the selector switch and/or thermostat to "Clean."
I have no power to my model 103738 toaster oven. Farberware
Is there power at the outlet? Is this in the kitchen where there is most likely a Ground fault outlet because it's close to a water source? If so, can the test/reset on the GFCI outlet be pressed? If not, then the outlet has done it's last save and needs to be replaced?
