20 Most Recent
Kyocera RI-4530 Black and White Copier Questions & Answers
System error
hi,
the c7100 error is a problem with the Auto Toner Sensor.
the first this to check is that you are using a genuine toner cartridge.
if you are please try to re-set the developer by keying in 1087 1087
then 130 press start and then start again once this is done please press stop twice, then 001 and start
if this does not fix it it may need either a new sensor or a new developer unit.
Kyocera mita 4530 jam code 22 there is no jam
Replacing the jam sensor should end the error code.If cleaning didn't remove the error,one of the sensor is stuck(internally).The insides of a sensor contacts driven by optical sensors or flip switches(it depends what models you have).If it is optical-either the transmiter ligth is dirty or the reciever is dirty too it needs contact cleaning(observe wiring connections too).If it is a mechanical switch-replacing the switch of the same type will do the job.
Install Duplex Unite?
pull out the bit (duplex unit) that sits under fuser/transfer section have a look inside see if there is any paper crushed at the back and slam it back in.
Pasword reset
This answer is for the Toshiba eStudio 45
hi,
im not 100% sure what you need help with so if you want to delete all the department codes on your copier but you do not know any of the current codes or the master code and need to change the master code follow these steps:
- turn the copier off
- while holding down 0 & 8 turn on.
- key in 672 press start
- press [INITIALIZE] (you might have to hit start if nothing happens i cannot remember)
- this could take a min then you need to turn the copier off and back on.
- you department codes should be cleared.
please let me know if i have helped or if i have not answered you question.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
