20 Most Recent
Connex 4400 320-Channels Base CB Radio Questions & Answers
Wanting info on my connex 4400 turbo how to peak and tune
unless you have the equipment to do this.. please take to a radio store. have them do it.. its free. or they shouldn't charge to do that service.. unless it needs a major factory alignment.
also they shouldn't take out or clip anything in the process if they do find you another place LOL..
Connex 4300
Check for proper shielding,ground, turn mic gain down, move mike farther away from radio, turn off other accessories nearby-ie.-am/fm radio
Ranger 2980
it wasn't the 4558 chip... am still hunting...
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
