20 Most Recent
Bunn GRX-W Questions & Answers
I bought a white Bunn
It takes 2 full decanters to fill the tank. You fill the tank with 1 full decanter of water and pour it into the top and close the lid-wait 3 minutes. Then fill the decanter again and pour it into the machine and close the lid. Plug it in and wait 15 minutes for the water to heat it up. Then you will be ready to brew coffee. You will pour in 4-10 cups of water at the top and have your filter basket ready with filter and grounds. In 3 minutes, you will have your coffee. If you have any questions, please call customer service at 800-352-2866.
1/18/2011 4:14:37 PM •
Bunn GRX-W
Answered
on Jan 18, 2011
It is shorting out, model GRX-W Bunn
Please contact customer service with the model and code date. If your machine is 3 years old or less, we can replace it free of charge. If the machine is over 3 years old, we can replace it at a reduced price.
5/19/2010 4:26:10 PM •
Bunn GRX-W
Answered
on May 19, 2010
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
