20 Most Recent
Deni / 5201 / 5202 / 5203 / 5205 Ice Cream Maker Questions & Answers
I need a manual.
You can download manuals from this site:
http://www.retrevo.com/support/Deni-5210-manual/id/22060dj895/t/2/
Bon appetit!
I have no manual Need to know how to make the ice
Try this manual, it explains how to use the ice cream maker and it has recipes as well:
http://www.deni.com/files/5200.pdf
Make sure you have adobe reader installed on your computer cause the manual is in a pdf format.
Deni ice cream maker #5203
http://www.wigix.com/item/2099031/Deni-Automatic-Ice-Cream-Maker-With-Candy-Crusher-5203---Lime#item_detail_view_upload_manual_tab
Suspected motor burnout
Yes I too would guess motor burnout ( Motor is very overworked as ice cream hardens) You could replace the motor but I would suggest buying a new one because the cost of a major repair like that may very well cost more then a new unit!
I hope I answered the question to your satisfaction!
Please rate my response!
Thank You!
Need instructions
I found someone who told me to go to the store and ask for a copy of the instructions so I will try that. Thanks
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Deni blueberry 5201 Ice cream maker...
While I can't tell you where to buy a replacement paddle, I can tell you we just bought this model of ice cream maker through Heartland America for $30. If all else fails... Hope this helps!
