20 Most Recent
Ecoquest Flair Air Purifier Questions & Answers
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
When ionizer is on even
Hi willy,
The ionizer itself shouldn't smell. I wonder if you're smelling O3 (aka ozone or activated oxygen), or if there's a short-circuit of some kind that is causing electrical components to overheat/burn. Burning electronics and singed hair smell more alike than ozone (which isn't the same as ionization, incidentally.
Write back with more details if you can, preferably with any details about your observations.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
How do you clean the ozone plates? By using household products.
Hi lawrsports,
I generally use household ammonia and an old toothbrush, rinsing thouroughly in clean water, and drying them thoroughly. And I do mean _thoroughly_, as-in bone-dry, use a hair dryer if in-doubt.
Putting anything wet, or even damp into a high-voltage environment is contra-indicated.
Jon
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Cleaning inside of system
Call (336) 499-2505 and they will email you cleaning instructions for free. Tell them you were on Fixya.com.
I was wondering about the filters
do i relace or
You can try washing them, but at least locate some new ones just in case. If the filters are made of paper washing will not work. Make sure the filters are completely dry before you reinstall them.
