20 Most Recent D-Link DIR-450 Router (DIR450) Questions & Answers
Continuous self restart and no
contact dlink technical support. from your description that your router keeps restarting. that is actually the symptom that your wireless router is already defective.
9/9/2011 4:41:42 AM • D-Link DIR-450... • Answered on Sep 09, 2011
2answers
Hello, My laptop died, so had
Hi James,
It sounds like you're halfway there. You now need to find out the IP Address that the USB convertor box is using by going into the D-link router. Note it down (including the dots separating them) and then go into the printer poperties of the printer on your laptop. (Sorry I don't which operating system you are using so I'm going to have to assume that you know how to do this. If not, drop me a line.)
Click on the Ports tab.
Click on the Add Port.. button below the list of ports
In th window that pops up click once to highlight the Standard TCP/IP Port option and click the New Port.. button underneath the selection box.
A wizard will appear. Click Next.
In the next window enter the IP Address you noted from the router noting the dots between the numbers in the Printer Name or IP Address box. (Note that the Port Name box will autofill.)
Click Next (you may have to wait a moment for the settings to take effect).
Another windows will open and the default selection is Generic Network Card. (Leave it as is and click next.)
The finish windows will appear. Check the settings . The defaults are as follows:
SNMP: No
Protocol: RAW, Port9100
Device: (The IP Address that you enterred earlier)
Port Name: IP_(The IP Address as above)
Adapter Type: Generic Network Card
Click Finish and get back the pinter properties page at the Ports tab.
Check that there is a check mark next to the port you have just created (i.e. IP_(IP Address you enterred earlier)
Click Apply and OK.
Return to the properties and print a test page.
Let me know how you go. Cheers.
12/18/2010 4:28:36 AM • D-Link DIR-450... • Answered on Dec 18, 2010
2answers
Where can i download driver for dlink dir 300
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thats it.
7/8/2010 6:16:11 AM • D-Link DIR-450... • Answered on Jul 08, 2010
Verizon Router/wamp server problem
That's actually normal. When the URL address is resolved you wind up at your own router. It's not a settings issue. You need to use a computer outside your own network to reach your page. If others can reach you then everything else is fine. (I found this out when setting up a server myself...couldn't figure out what I was doing wrong when I kept my router. I eventually found out through a forum somewhere but can't remember where it was.)
2/17/2010 9:23:56 PM • D-Link DIR-450... • Answered on Feb 17, 2010
2answers
Unit see's KPC-650 but can't
Hi First, are the drivers installed so that you can see the network but you just can't connect to it? Is the card activated? To get the Pc card activated contact the service provider I assume you mean Verizon United States Verizon Wireless www.verizonwireless.com 1-888-466-4646 When your card is activated you should be able to connect to Verizon network, this will have to be done directly with verizon we can't do it for you.
11/24/2009 9:03:07 PM • D-Link DIR-450... • Answered on Nov 24, 2009
Do the Acer Aspire One netbooks only work with GSM
you need to purchase a separate hardware for cdma to make it work with verizon as the one that is with your netbook is for GSM only
11/7/2009 2:55:37 PM • D-Link DIR-450... • Answered on Nov 07, 2009
Can't access the router setup screen
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
10/5/2009 6:11:36 PM • D-Link DIR-450... • Answered on Oct 05, 2009
My verizon p5750 internet pc card not connecting to WAN on my DIR-450 wireless router
Download the new firmware for your router. Should be able to locate it on the D-link site. Log into the router and let it update. Instructions on how to do this are in the manual or online. This should solve any connection problems with your router.
5/25/2009 6:55:48 PM • D-Link DIR-450... • Answered on May 25, 2009
I have a D-Link DIR 450 which I have been using with good success with my old Verizon PC5750 card. I just got a new PC5750 card. I have my D-Link box but there is no sw in it. Is there supposed to be.
If you already programmed it, yea hit the reset hold it down for at least ten seconds. And sometimes its not your home's fault, sometimes your internet service provider has problems, it would be a coincidence but just to cover all the bases I would have them check your connection make sure its ok.
5/1/2009 7:57:36 PM • D-Link DIR-450... • Answered on May 01, 2009
Does it work verizon wireless un175 usb on dir-450?>
yes...you must change the D Link IP address and disable the DHCP server...use the IP add within the range of verizon dhcp server..192.168.1.1 is your verizons IP..to chANGE your di link IP connect to Dlink wired and not connected to any routers...type 192.168.1.1 to access configuration menu and you can change the setting
4/6/2009 7:40:42 AM • D-Link DIR-450... • Answered on Apr 06, 2009
My verizon UM175 usb modem will not connect to my acer aspire one
- Verify the Internet settings of your USB modem by calling the Verizon support.
3/8/2009 10:49:55 PM • D-Link DIR-450... • Answered on Mar 08, 2009
Hi I cant get my computer to recongnize my Verizon P5750 PC card
Uploading the latest firmware of the router in order to recognize the card.
3/8/2009 8:55:32 PM • D-Link DIR-450... • Answered on Mar 08, 2009
Cannot connect to router
Are you typing at your browser the correct IP address?
Is your router connected to your pc via ethernet cable?
If yes, reset your router (insert pin on a small back hole)
Your ip must be http://192.168.0.1
Your default setting (D-Link) are:
user= admin
pass= (blank) no password
You can also see this:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
11/2/2008 8:59:22 PM • D-Link DIR-450... • Answered on Nov 02, 2008
D-Link Dir 450 configuration problem
It seems like the routers firmware might be corrupted what you can do to solve these problem is basically upload the same firmware and check to see if solves problem.If not you might want to contact Dlink for further support even possibly a replacement if hardware is bad.
9/4/2008 4:59:44 AM • D-Link DIR-450... • Answered on Sep 04, 2008
Can't get on the system or gets kicked off by something called bandit
This router may need an updated code for when l phoned them l needed one and now it works great
7/18/2008 8:28:54 PM • D-Link DIR-450... • Answered on Jul 18, 2008
2answers
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
11/12/2022 5:02:31 AM • D-Link Computers... • Answered on Nov 12, 2022
My d-link dwm-156 3g after upgrading its firmware don't working!
I am sure it is now toast and you cannot downgrade if the wrong firmware has been installed. I would ask D-Link.
5/10/2022 11:44:35 AM • D-Link Computers... • Answered on May 10, 2022
2answers
I want to know how to setup the VPN on the D-Link 2750U modem
https://www.youtube.com/watch?v=zKeXtyUMKjA Check out this video it might help you with your issue.
12/22/2021 5:56:00 PM • D-Link Computers... • Answered on Dec 22, 2021
2answers
Multicast
Please open router page and go to advanced just like in this emulator. http://support.dlink.com/emulators/wbr2310/adv_network.htm
10/11/2021 6:58:31 AM • D-Link Computers... • Answered on Oct 11, 2021
D-Link DIR-450 Router (DIR450) Logo
Popular Tags
24 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
d link dir 450 using good success old
  • Computers & Internet
