20 Most Recent
LG LMVM2055 Convection/Microwave Oven Questions & Answers
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Lmv1630bb microwave reset
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Only a few buttons on
Yes you can use a hair dryer but the power should be off so that you don't short it out any more than it already is. Most likely the keypad has been ruined and will need replaced., Once these go bad there is no fix except to replace the keypad.
MICROWAVE BUTTONS WILL NOT RESPOND
Hi and welcome to Fixya, I am Kelly.
This is usually from the Child lock being activated:
1. Touch STOP/CLEAR.
2. Touch and hold START/ENTER more than 4 seconds.
LOCKED will disappear and two beeps will sound.
Thanks for choosing FixYa,
Kelly
Hi, my microwave fuse blows when start button is
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the !!!!any
capacitors are discharged!!!!! before attempting any sort of
repair.
Check the door interlock switches first then the high
voltage diode with either an AVO model 8 or moving coil meter on high
resistance range for short circuit, (DVM's won't show the fault!),
the capacitor can fail and go short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
Microwave not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
My LG LMVM2055 just stopped
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
On stove bulbs what is
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
The buttons on my microwave stopped working and it
You likely have a shorting
membrane keypad.
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
