20 Most Recent Sony CRX320EE CD-RW/DVD-ROM Combo Drive Questions & Answers
2answers
Does not recognize DVDs, computer
I would like to suggest that you attempt to download & install the codecs that your media player requires, before it will play a DVD.
I found this typical when I was using the Vista operating system with Windows Media Player 11.
The codecs can be found as freeware online & a good site for the apt codecs for WMP 11 is @ www.majorgeeks.com once you are on the site, click multimedia on the left of the page, then scroll down to the codecs required.
The K-Lite series of codecs seem to work well with WMP 11 on Vista.
I truly hope that this has resolved your problem, as there is nothing better than watching a fine movie on the old PC.
Failing my advice, you could always 'Rip' the said movie to your media player & view it from your hard drive.
Good luck anyway.
Warmest regards,
Ste
4/29/2020 9:06:40 AM • Sony CRX320EE... • Answered on Apr 29, 2020
Hi, I've SONY Combo crx 320 AE installed in my
go to hardware manager and uninstall it. then let it find it again, should fix it.
5/2/2017 7:17:30 AM • Sony CRX320EE... • Answered on May 02, 2017
How do i download sony t5058159
Assuming it is an internal drive, and it's hooked up properly, most of the time all you need to do is reboot your computer. The computer will recognize it as just a plain disc drive without proprietary drivers, but it will recognize it. It sounds to me like you might have either a bad connection or perhaps the ribbon isn't pushed all the way onto the pins. Does the light on it blink when you start up your computer, before Windows (you are using Windows, right) starts up?
3/30/2014 4:01:39 PM • Sony CRX320EE... • Answered on Mar 30, 2014
Burner working
What operating system do you have? The drive is fully supported by XP onwards and should be auto detected. You may have to delete the current driver in device manager reboot & Windows should install a compatible driver. (Start > right-click computer > properties > Device Manager > DVD Drives > Highlight faulty drive and delete > reboot) Also, WinXP does not allow you to burn DVDs unless you have appropriate burning software installed (e.g. Nero)
1/17/2014 2:48:43 PM • Sony CRX320EE... • Answered on Jan 17, 2014
0answers
Need driver
Right click on this drive in Device Manager, and allow Windows to search for the correct driver on the Internet.
11/3/2013 3:16:01 AM • Sony CRX320EE... • Answered on Nov 03, 2013
2answers
How to install cd-rw/crx320ee drive
installing CD drive no need installation driver, just install it like install Harddisk drive but you need to open the slot for your CD drive (dont forget to screw it). after u finish install it just reboot your computer, then the CD will automatically installed.
hope this useful.
1/11/2013 12:22:47 PM • Sony CRX320EE... • Answered on Jan 11, 2013
DEAR SIR, I HAVE AN
is any dvd the program or just wont read any dvd?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
9/9/2011 4:12:38 AM • Sony CRX320EE... • Answered on Sep 09, 2011
I have an lg external
CD/DVD drives will always show 0 bytes if there is no media present.
You will need extra software in order to burn DVD such as Roxio, Nero. I beleive the LG burners show come with software, you will need to install it in, and run it to burn DVDs.
Nero does offer a free version that will burn DVDs http://www.nero.com/ena/downloads-nero9-free.php
Comment back if you need more assistance
8/23/2011 4:45:46 AM • Sony CRX320EE... • Answered on Aug 23, 2011
In my CD drive, the
Kindly reinstall its driver and make it jumper settings properly.Good Luck
8/7/2011 4:14:00 AM • Sony CRX320EE... • Answered on Aug 07, 2011
My DVD combo does not
Welcome to FixYa!
You can upgrade the firmware version by going to this link:
http://www.sony-optiarc.us/en/support-service/downloads/fw_cd-writer-dv-series3.htm
Hope this helps :)
8/7/2011 1:35:12 AM • Sony CRX320EE... • Answered on Aug 07, 2011
I can't find crx320EE driver!
make sure that the cd-rw/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd rw then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
4/26/2011 7:29:45 PM • Sony CRX320EE... • Answered on Apr 26, 2011
In my sony dvd combo
HERE IS WHAT YOU DO .!
is it new if its new then look for the customer support center for warranty and if its out of 6 months warranty then clean your DVD combo with cleaner and then check the SATA cable if its attached properly ,,, and also change the power supply wire, just for a check , if problem don't persist then may be you have a power supply issue... cause DVD power usage is a little high, and CD's take low POWER , just some points difference .
do vote if it helps
4/3/2011 9:29:46 AM • Sony CRX320EE... • Answered on Apr 03, 2011
DVD/CD-ROM > Does not
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps don
3/12/2011 3:56:36 AM • Sony CRX320EE... • Answered on Mar 12, 2011
When I insert blank DVD
My first test would be to determine if the blank DVD is faulty. Try using a different brand of DVD and see if you get the same error. My experience tells me that your combo drive is faulty however. It is possible for a combo drive to read a CD but not a DVD. I would replace the combo drive with a DVD writer as they are not too expensive.
Best wishes,
Graemevm
3/4/2011 6:57:36 AM • Sony CRX320EE... • Answered on Mar 04, 2011
My dvd player read &
Just click on the link http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
and also click on NOW RUN from right side box. It will automatically give youthe message, well or bad.
If the problem with the lens, you should try cleaning the lens,with diskcleaner, it's already gone bad and there is no harm to take a risk toopen or disassemble the dvd/cd rw,click on the bellow link http://www.youtube.com/watch?v=WaiTJYHQCCg 1. When running your pc, open the drawer.> 2. clean the optical lance 3. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html 4. now you can fit to your pc If it does the same problemplease change the cd/dvd rw because the lance has defected.
Hope this helps
2/19/2011 3:50:11 PM • Sony CRX320EE... • Answered on Feb 19, 2011
I cannot read any dvd by using my sony CRX320EE
install
2/18/2011 5:16:42 PM • Sony CRX320EE... • Answered on Feb 18, 2011
Sony CRX320EE CD-RW/DVD-ROM Combo Drive Logo
70 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
install cd rw crx320ee drive
  • Computers & Internet
