20 Most Recent Acer Aspire T690 (AST690UP820A) PC Desktop Questions & Answers
How much RAM memory can I install in Acer Aspire T690-ED210A
Maximum is 2 Gb (1 GB x2) dual Channel RAM.
11/25/2015 10:30:40 PM • Acer Aspire ... • Answered on Nov 25, 2015
Cannot get cover off old acer aspire desktop
check the back there might be some screws in the back holding the panel in like my aspire t690 has two screws top and bottom and after you take them out you have to push down on the quick release
9/27/2015 4:38:15 AM • Acer Aspire ... • Answered on Sep 27, 2015
How much RAM memory can I install in Acer Aspire T690-ED210A, 320 GB hard drive
2GB max here is your specs for that pc... Acer Aspire T690 Specs CNET
3/31/2015 2:15:44 AM • Acer Aspire ... • Answered on Mar 31, 2015
I need to restore my
Assuming the Recovery Partition hasn't been disturbed, boot the machine and press ALT + F10 at the same time. You will enter a recovery phase that will give you the option of restoring to factory settings. If the Recovery Partition HAS been either disturbed or wiped out, you will not be able to restore to Factory Settings without a set of disks from Acer.
4/25/2014 12:02:59 AM • Acer Aspire ... • Answered on Apr 25, 2014
I need a wiring diagram for my acer t690
Viewing this video might help. Or contact Blueblurr444. http://www.youtube.com/watch?v=zCyhwXtT0lw
11/22/2013 7:57:47 PM • Acer Aspire ... • Answered on Nov 22, 2013
5answers
On COD4 I keep on getting this problem: UBYTE4N vertex data.
i have the solution just go to http://www.mediafire.com/?iii8fdwc72e6svj and take one of the dll files and put it in the document of your game and it will work I've tried it in mw2
8/21/2013 11:16:06 AM • Acer Aspire ... • Answered on Aug 21, 2013
0answers
0answers
Bios update
Be the first to answer 5/6/2013 7:17:58 PM • Acer Aspire ... • Posted on May 06, 2013Be the first to answer
Changing acer t690 processor
Yes, you can change the CPU, but your Motherboard will only support certain processors, Take a look at this Acer Support, you will see the compatible CPU's: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT690/AspireT690sp2.shtml Remember : Your machine's component work with one another, within parameters, one component,CPU, will not give you the improvement you might think. CPU, Memory, Graphics Card, Etc.,Upgrades, require more Power/Watts, therefore a new PSU. Which create more heat, new fan. One relies on the other. Do your research, their's a lot more to it than replacing one component. Do a comparison, what will all the components cost, to a new System? The prices for new Good Systems , are low due to slow sales of Desktops/Laptops.
2/5/2013 8:41:22 AM • Acer Aspire ... • Answered on Feb 05, 2013
How to reinstall vista home operating system
you can get the answer from HERE
1/11/2013 8:16:19 AM • Acer Aspire ... • Answered on Jan 11, 2013
Acer aspire t690 wont connect to internet
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
1/11/2013 12:54:15 AM • Acer Aspire ... • Answered on Jan 11, 2013
My acer aspire sometimes dont boot how can i fix it.....
The best answer is reinstalling the operating system.
1/10/2013 10:12:38 PM • Acer Aspire ... • Answered on Jan 10, 2013
4answers
Acer Aspire AST690 won't boot, just beeps.
Hi..
This is an Hardware Failures: Doesn't Boot Up.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
You need to check the memory stick this is the first to diagnose the problem of beeping. Remove the memory stick clean the dust, and reinsert the memory stick, try to use the other memory slot.
Thanks for using fixya
Regards
PCmania
1/9/2013 5:45:40 PM • Acer Aspire ... • Answered on Jan 09, 2013
My computersays VERYFYINHDMI poolupdate then turns on after blue screen
bluescreen can be caused by a number of things
a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to failmake sure all leads have a dust free secure connections
a bad driver loose or faulty lead or not having enough ram
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchaseif you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentialshope it helps
10/16/2012 5:44:49 PM • Acer Aspire ... • Answered on Oct 16, 2012
My computer is acer aspire acer t690.do you think it is harddrive
it looks like sata Aspire T690 Specifications
Part Number: AspireT690 Aspire T690 Storage CD-ROM, CD-RW, DVD-ROM, DVD/CD-RW Combo, DVD Dual, or DVD Supermulti (varies by model)Up to 400GB Hard Disk Drive SATA (varies by model)9 in 1 Card Reader (selected models)
10/15/2012 10:56:47 PM • Acer Aspire ... • Answered on Oct 15, 2012
2answers
Can your Hardware (network/monitor) cause your
Of course, but it should be a major failure that would make them practically unusable - not your case. You most likely use IE and it's a POS that crashes with regularity when it's encountering a more demanding site. Just use another browser and your problem  will go away. Don't forget to scan your pc for malware before.
10/8/2012 3:15:04 PM • Acer Aspire ... • Answered on Oct 08, 2012
Missing network drivers
If you are using windows Vista in this computer, then you just need to hook this computer to an Ethernet cable connecting one port to the router and another to the tower(CPU).once you done with that, restart the computer, so that you will be able to go online.
9/11/2012 3:17:24 AM • Acer Aspire ... • Answered on Sep 11, 2012
Can i run new ati radeon 512mb video memory with 5.0 shader card on acer ACER AST690-U-P925A
1) How much Ram Memory do you have installed? If I have the spec's right, your motherboard's maximum amount of Ram Memory is 2GB.(PC2-5300 would be best, but the amount is what matters, not the 'speed')2) What is the Maximum Wattage for your Power Supply?Takes power for each hardware component in the computer.Motherboard, Processor, Ram Memory, Harddrive, Optical Drive/s, Graphics Card, etc.When purchasing a graphics card, this is one of the minimum system requirements you need to know.Spec's I looked up indicate a 300 Watt power supply.This is the problem. That, and power supply's Acer uses are low quality.If you had at least a 400 Watt power supply, you could use this,http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=41125&Sku=E145-0550Slap that game around, and make it bark.http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483You could also run this if you had the above Power Supply,http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2048679&Sku=M452-7770[Note*No. It does not matter if you are using DDR2 Sdram ram memory, and the graphics card has GDDR5 graphics memory.A graphics card runs independent of the system resources.(Processor and Ram Memory ]For additional questions please post in a Comment.Regards,joecoolvette
7/26/2012 12:47:33 AM • Acer Aspire ... • Answered on Jul 26, 2012
Computer cannot boot - just beeps when switched on
Remove and reseat your RAM chips
1/22/2012 11:14:18 PM • Acer Aspire ... • Answered on Jan 22, 2012
3answers
How do i get the @ on my acer keyboard. it just
this is a common manufacturers problem believe it or not. if you press shift and use the quotation symbol then it should be the @ sign.
12/30/2011 12:16:34 PM • Acer Aspire ... • Answered on Dec 30, 2011
Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
155 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
changing acer t690 processor
  • Computers & Internet
