20 Most Recent
Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier Questions & Answers
There is a onkyo service center in saudi arabia riyadh
Hi Benjie, you would have to contact your local distributor, I have noted the contact information below:
Adawliah Universal Electronics Apl
Distributor
Address
P.O. Box 2154, 31952 Al-Khobar, Kingdom of Saudi Arabia
Phone
+966-3864-3601
Fax
+966-3898-1541
E-mail
Sales (Purchasing) Inquiries
Web Site
http://www.adawliah.com/
Thanks, JT
Thanks, JT
Onkyo Struck by Lighting
before taking it to an authorized center , check the main power supply section for any fuse or circuit breaker . good luck AJ
Onkyo amplifier
Is power coming out of transformer at the right voltage. Also may have a power i.c. shorting to ground.Final anp i.c. may have a place to go to ground through a shorted capacitor.
GOOD LUCK
Big Red
Light on volume
The problem is most likely in the unit. You could have a burned out lite or just a bad connection to the lite. You can take off the volume knob by just pulling on it and checking it out thier, then take the top cover off and follow the wire from the knob and check out the connections.
HDMI Problem help me
With onkyo amps with hdmi up scaleing you have to tell the amp to let the signal through.To do this first press the setup button and you will see input assign,press enter,monitor out appers,press enter you will see hdmi out NO,flick enter button to the right this will change to yes,you should have a picture now.
hope this helps.
CABLE GUY.
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Blinking video
check the tv setting for aspect ratio and make sure it matches the one coming from the cable box.
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
What's the error M1.04/19912A50?
The error code M1.04/19912A50 on your Onkyo AV receiver HT-R398 typically indicates a firmware or software-related issue. To resolve this problem and reset your receiver, you can follow these steps:
- Power Cycle the Receiver:
- Turn off the receiver and unplug it from the power source.
- Wait for about 10-15 minutes to ensure that all internal components have fully powered down.
- Plug the receiver back in and turn it on.
- Factory Reset:
- If the error persists after power cycling, you may need to perform a factory reset to restore the receiver to its default settings. Note that this will erase all your custom settings, so make sure to back up any important configurations if possible.
- To perform a factory reset, refer to your receiver's user manual for specific instructions. Typically, this involves pressing and holding specific buttons on the front panel while powering on the receiver. The exact combination of buttons may vary by model.
- Firmware Update:
- Ensure that your receiver's firmware is up to date. Visit the Onkyo website and check if there are any firmware updates available for your HT-R398 model. If updates are available, follow the provided instructions to update the firmware.
- Contact Customer Support:
- If the issue persists after trying the above steps, it's a good idea to contact Onkyo customer support or visit their official support website. They may be able to provide specific guidance or solutions for the error code you're encountering.
Remember to consult your receiver's user manual for model-specific instructions, as the steps to reset or update firmware can vary between different Onkyo models. Additionally, be cautious when performing a factory reset, as it will erase all settings and return the receiver to its default state.
