20 Most Recent
Creative Labs Inspire T3030 Computer Speakers Questions & Answers
Broken Volume Control
try ebay or bizrate
it may be easier than you think to fix it.
look for a new cable or a similar end piece and you can splice the new cable onto the old one.
if you would like when you get a new cable i can assist you step by step to fix it.. you will need to get electical tape and wire cutters/strippers
My speakers just for some
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps if you don't have the drivers you will need to download them http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
T3030 speaker system with wired
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
I use the system in
This sounds like the power adapter for your speakers is not working.
If you have some electronics experience you can test your adapter with a multimeter or maybe have someone else do it for you.
If you plan to replace the adapter, (if it is the adapter that is not working) be sure to use the same AMP and Voltage rating that is on the original.
How do i set up
Ty this - there is one wire with a green end - plug this into the sound card on your pc.
Take the one wire from the left speaker and plug it into the main control box to the matching plug.
Take the remaining wire and plug it into the other matching plug on the back of the main LARGER control box.
Plug it in the wall socket.
Play music on your pc.
Hi, Is there a plug that will allow bulk printing
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREESelling Manager is an online tool designed for medium-volume sellers to help
manage and track listings on eBay. Selling Manager is conveniently located in My
eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping
labels at one time from the Sold View.
To print multiple invoices and shipping labels:
In the Sold View, check the box next to the listings that you want to print
invoices or shipping labels for and click the Print button.
To select all of your Sold items, check the box in the heading bar above
the list of sold items
From the Print page, select the printout you want, and click the Continue button.
In the pop-up window that appears, use the scroll bar to preview each of the
pages that will be printed.
Once you are satisfied with how the pages will look, click the Print button in the browser window.
If you need to edit information for a specific page, go the corresponding
sales record. When you are finished updating the sales record, save your
changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
