20 Most Recent
Microsoft LifeCam NX-6000 Webcam Questions & Answers
My webcam wont work on chatroulette but works in
sometimes certain drivers can only be supported on certain sites. it's a big possibility that the driver that your camera uses is not supported on their site. I would suggest buying a different webcam. that's my biggest guess. because I had this same problem as well.
8/28/2012 1:23:59 PM •
Microsoft...
Answered
on Aug 28, 2012
If I was to get
Yes, it is perfectly possible! All you need to do is connect the webcam via USB to your Netbook and insert the Installation CD and follow the Setup Wizard.
Have fun :)
8/15/2011 11:02:08 PM •
Microsoft...
Answered
on Aug 15, 2011
I have a Lifecam Show
Welcome to Fixya. With you issue the work around is to reinstall the latest driver of the webcam to see if it will works. We can isolate the issue to know if the product is defective. If it is possible to connect the Lifecam or try it to a different computer so that we can check if it has the same result. If the colors will still continue to flicker the most likely this is a problem with a hardware and it only means that you need to replace the lifecam.
Thanks
6/19/2011 9:47:22 PM •
Microsoft...
Answered
on Jun 19, 2011
I want to use the
Not possible it only has drivers for microsoft operating systems sorry.
5/12/2011 11:27:26 PM •
Microsoft...
Answered
on May 12, 2011
I can take pictures with my webcam it just wont
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
11/22/2010 4:54:20 PM •
Microsoft...
Answered
on Nov 22, 2010
I had been using a
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
11/16/2010 6:55:51 PM •
Microsoft...
Answered
on Nov 16, 2010
