20 Most Recent
Philips Magnavox 20MT4405 20" TV Questions & Answers
My AV channel stopped working...
try another device on this input to see if it is the input, the cables, or the video output of you player.
Also try player using rca cables on the dvd input if they are the yellow, red, and white jacks.
Usually vcr input for coaxil hookup is channel 3 or 4.
The top 2 inches of
You have a bad capacitor in the vertical deflection. I have not repaired this particular model. I'm aware of this happening in many of the Magnavox brand. You will have to locate the vertical IC. It may have seven or nine pins (remember, I have not repaired this particular TV) and is mounted on an heat sink. You will have to inspect this IC and resolder the pins. Do not use excess solder, you do not want to short the pins together. Next you will need to replace the capacitors that are near and next to the vertical IC. We are looking at about 4 capacitors, two will need replaced. You may replace the other two if feel you need to, or do not have a capacitor checker. Be sure you solder in the correct values and polarity of the caps as you replace these. You may, also look for a bad capacitor near the flyback transformer. It may be a 100 volt 10 Mf capacitor here, that is also bad.For the TV man this is a simple fix. For the average guy, it may be some effort to fix. Thanks for asking and show all hands of support.
Blank tv screen when turned on
the problem is in your tuner section or video if section
check for its proper voltage.
if you are not tech. person get the help of tech person
it is not a major problem.
At the top of the
I, thats a vertical circuit problem with some capacitore ,they are leak or dry
and at the same time you replace the vertical ic and verify for bad soldering
in the vertical circuit.
hope the will help you
regrads Alan
Magnavox 19prc1 0121
There aren't any adjustments anymore. This can happen as parts inside age and values change. Also solder connections can fail over time and cause problems. The problem you describe can be in any of several areas of the set. There really isn't anything you can do yourself to repair this. If you want to keep the TV you can get an estimate for repair, but this might be a good time to check out sale prices on new TV's and think about replacing it.
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
