20 Most Recent
TruTech TT320 Questions & Answers
Display is stuck in Spanish.
on your remote for your dvd player hit your menu button then hit options it should have an option to change languages.
My TT320 has stopped responding
Possible fault in the microprocessor of the unit, failure of the controller can result in non functioning of the control panel and remote system.
So remove the top cover and check the +5 volt to the micrroprocessor inthe main board. if there is supply to the IC then the crystal oscillator must be checked. Attempt only if you are versed with knowledge of such mP boards or else it might be better to consult the service dealer thatn to tamper.
measurement of the oscillation might be important to confirm the mP and sections. Possible failure of the mother board cannot be ruled out.
Where is the pin hole
The TT 320 does not have a pinhole, it has a slot. Push a small stick thru the slot under the unit and slide it across the actuator switch.
The DVD drawer will not open
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
It does'nt turn on don't respond any comand The
I had a problem similar to this. I fixed it by toggling through the top buttons on the remote control. Sometimes the wrong button gets pressed and the remote cannotcontrol the unit it is supposed to. i.e. make sure TT320 remote has good batteries and then make sure if it has other buttons on it like TV, cable, DVD etc that the correct one is pressed to control the TT320. My TV remote would not control my TV and by chance my kids had pressed the satellite button so I had to press the cable button and then the controller startedto control the TV again.
I have the TruTech DVD
This DVD player have power supply board and the laser eye reader problems.DVD player very cheap these day.Can buy a new one about $40.So the old DVD player,junk it,not worth fixing.
10/21/2010 10:21:18 PM •
TruTech TT320
Answered
on Oct 21, 2010
Everytime i put in a dvd it says "no disk". How
Hi, well i see this all the time in my shop, what has most likely happened is your laser head assembly has faulted, this is common. Now one has little option but to replace it. Now this is dependent upon parts availability and costings.
Unfortunately these are not that great in quality, and the lasers seem to fault often.
One could attempt repair oneself, but getting hold of a service manual, so you can get the part number(s) and service may be difficult.
My professional advise would be to take your unit to a reputable repair shop, and ask for a "Quote" before starting any repairs, as often these days the cost of repair may approach,or even exceed the cost of things these days. Also often the money, that would have been used to repair, would be better spent obtaining a new unit, different unit, with a warranty.
