Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys
IP PhoneThis document explains how to use Brekeke SIP Server with
the Linksys IP Phone SPA hard phone .
The Standard features include
two active line appearances, call forwarding, redialing, speed dialing,
transferring calls, conference calling and accessing voice mail. For
more information regarding this product please go to
www.linksys.com
Configure Linksys PhoneSet
up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and
subnet mask (e.g. 255.255.255.0).
Once the IP address is
configured you can access phone webpage by its IP from web browser (e.g.
http://192.168.0.15).
Network SetupClick on "Admin Login", then
select “System" tab. Sign Static IP, Gateway and NetMask.
Use
the following data as an example
- Static IP: Linksys phone IP
(e.g. 192.168.0.17)
- Netmask: 255.255.255.0
- Gateway:
not needed if SIP Server is in the same LAN as Linksys phone
- Click
on [Submit all changes] button now to reboot you phone,
or after
whole setup is finished
Phone ConfigurationSelect tab
Ext1 or Ext2 and enter SIP server information and sign extension number
Use
the following as an example to complete the phone configuration.
- Proxy
and Registration:
- Proxy: Brekeke SIP Server’s IP address
(e.g. 192.168.0.69)
- Register: Yes
- Subscriber
Information:
- Display Name: extension number or Name (e.g.
400 or Alice)
- User ID: extension number (e.g. 400)
- If
user authentication is set on at Brekeke SIP Server,
type in the
same information at Auth ID and Password as what you set at SIP Server
side
and Use Auth ID: Yes
- click [Submit All
Changes] button to restart the phone
Brekeke SIP Server’s Registration PageClick
the [Registered Clients] tab at Brekeke SIP Server admintool.
The
Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
