20 Most Recent HP Compaq Presario SR2150NX PC Desktop Questions & Answers
Computer
From what I have found, that system should come with a DVD-RW drive by default.
  1. Check device manager, see if the drive is detected by Windows as a DVD type drive.
  2. If the drive is ID'd as a DVD drive, but will not browse a DVD movie in MY COMPUTER then there is a failure of the DVD optics of the drive and it needs to be replaced.
  3. If you can browse a DVD, but not play one, then you most likely need a DVD codec installed to read DVDs. Search google for the K-Lite Codec pack.
  4. If you are trying to burn to DVD media, ensure you have a DVD buring software installed as XP has no native DVD burn capability.
12/23/2021 7:14:37 PM • HP Compaq... • Answered on Dec 23, 2021
We have purchase several desktop
NO OS stated why skip that? XP,? SURE ITS CORRUPTED ALL ARE NOW. and will get works, dead now for 3 years at MS. the coin cell battery is dead if time clock fails. for sure the clock in BIOS screens !!! the NIC chip, or the Ethernet chip can be on board or an actual NIC, nic means network interface card. SR2150NX (HP retired this for support)official. 10 years old at least. some came with VISTA is it VISTA, be nice to say. does have this old slow chip Integrated 10/100 Base-T networking interface on board, or has addin board, open case look? see what board added,? like giglan card? the HP site clearly shows this chip Realtek RTL8100 the driver can be had at realtek http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1 I run a system PCI sniffer to get all chip true names, no screw driver need no mag lens to read chip tops. or here http://driverpacks.net/driverpacks/windows/xp/x86/lan 27million drivers now, happy hunting. 3 ways to get them here. (HP, chip maker, or way3 seen here) http://www.pcdied.com/Drivers.html the first chip to get working with PC that runs is what RTL8100, but you cant because its dead LAN. so only at a PC connected to the web can you get it and move it to dead pc. dead LAN. (called sneaker net in the old days) sneaking PC to PC.
8/30/2017 11:35:40 PM • HP Compaq... • Answered on Aug 30, 2017
I turn the monitor and the LED goes green then amber. Monitor is blank.
Hello "A" Well, start verifiying these: 1) Bad Module Ram 2) reseating video card. some other problems, more deepest are bad capacitor, near the CPU.
1/26/2017 4:56:46 PM • HP Compaq... • Answered on Jan 26, 2017
What is the difference between a (RR790AA} AND A (RR790AAR) ?
Are you looking to replace you power supply?
3/4/2015 7:54:22 AM • HP Compaq... • Answered on Mar 04, 2015
2answers
Will low CMOS battery cause compaq presario sr2170nx not to boot?
Yes it will kill boot, esp. If there are ANY changes!!
1/22/2015 3:43:29 PM • HP Compaq... • Answered on Jan 22, 2015
Power button won't turn machine on at times, green like flickering in bac
Your computer Is on with green lite, monitor, hookup, card problems? U dont give enough info? Try with different monitor. Also diff. Computer
1/9/2015 6:48:08 AM • HP Compaq... • Answered on Jan 09, 2015
Why won't my HPSR2150NX boot up
Many possible causes. Hard disk could have gone bad or simply unplugged for one. Do you get any errors on screen? If the screen stays blank, and no lights come on, the power supply could have gone bad. That happens, too.
8/25/2014 10:28:46 PM • HP Compaq... • Answered on Aug 25, 2014
Reboot compaq presario
You possibly have a system related issue, Windows or Linux can't find boot file in system folder. Usually repair utility helps, system rollback if available, or put bootable windows/linux DVD in your drive and choose repair in selection.
8/25/2014 9:52:58 PM • HP Compaq... • Answered on Aug 25, 2014
How do i know how much memory I can install
Download the manual to the mother-board to your system. It will have all details about the memory capacity. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
6/28/2014 6:16:34 PM • HP Compaq... • Answered on Jun 28, 2014
My hp compaq crashed! i tried installing new os
Try disabling uefi secure boot in BIOS
6/8/2014 9:22:14 AM • HP Compaq... • Answered on Jun 08, 2014
Compaq Presario sr215onx will not power on to
You probably still have a bad power supply.
5/9/2014 8:42:19 PM • HP Compaq... • Answered on May 09, 2014
Black screen
do you hear any system beep on boot ? if you do , and you still have a blank screen you have a faulty monitor or cables
4/24/2014 9:07:21 AM • HP Compaq... • Answered on Apr 24, 2014
2answers
Presario sr1710nx what type memory
Crucial.com has an excellent wizard for locating memory. Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC... Lists memory compatible with your machine. Memory Type: DDR PC3200, DDR (non-ECC) Maximum Memory: 4GB Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
3/2/2014 9:58:16 PM • HP Compaq... • Answered on Mar 02, 2014
Battery died and now won't communicate to monitor
Connect the AC power adapter to the notebook and see if that'll solve the problem.
1/7/2014 3:51:41 AM • HP Compaq... • Answered on Jan 07, 2014
Battery died and now doesn't communicate with monitor
The only battery would be the cmos which is most likely a cr2032 which you can pick up for about $3.00. After replacement you need to go to F1 and correct the time and date, then you are good to go.
1/6/2014 7:45:11 PM • HP Compaq... • Answered on Jan 06, 2014
SR5350F fan is loud
replace the fan with new one.
1/5/2014 1:54:26 AM • HP Compaq... • Answered on Jan 05, 2014
2answers
I want to upgrade my pc
The brand of RAM is not important, it's the type, you'll need SDRAM for that and an AGP4X type of graphics card... here's some several selections
GEFORCE4MX440SE/6M AGP4X
SIS 315, 256-BIT AGP 4X VGA CARD
GREEN ATI 7000 SERIES CARD
Hope this helps... Just don't forget to rate - thanks.
11/30/2013 4:52:29 PM • HP Compaq... • Answered on Nov 30, 2013
My compaq presario wont load it keeps telling me
Well my friend in that case you need to take the backup of the imp documents from you hard drive and then restore the system to factory setting by pressing F11 key during boot
10/21/2013 7:57:05 AM • HP Compaq... • Answered on Oct 21, 2013
HP Compaq Presario SR2150NX PC Desktop Logo
211 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
getting occasional warning from norton
  • Computers & Internet
