20 Most Recent
Amana AEW4530DDS Electric Single Oven Questions & Answers
Neither of my electric double wall ovens do not
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Amana AEW4530DDS cancel button the only button to
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Touch pad screen is broken, only some of the keys work
THIS IS A TOUGH SPOT BECAUSE YOU HAVE A GOOD WORKING OVEN BUT YOUR CONTROLS ARE SHOT AND THE REPAIR PRICE IS HIGH. THE TOUCH PANEL YOU NEED IS A PART #
5765M474-60 PCB DISPLAY AND IT RETAILS FOR $263.33 JUST FOR THE PART. WHAT SOUNDS LIKE MAY HAVE HAPPENED IS THE PANEL BROKE SOME OF THE WIRE MEMBRANES IN THE PANEL ITSELF. THE MEMBRANES ARE JUST VERY THIN FLAT WIRES THAT RUN ON THE BACK OF THE TOUCH PANEL AND THE DAMAGED ONES ARE THE ONES YOU CAN NO LONGER OPERATE. THE REAL QUESTION TO ASK YOURSELF IS HOW MUCH IS THIS OVEN WORTH AND IF REPAIRED HOW MUCH LIFE TILL YOU THINK IT MAY NEED TO BE REPAIRED AGAIN. YOU MAY BE BETTER OFF USING IT TILL IT FINALLY DIES OR REPLACING IT. HOWEVER IF YOU REALLY ENJOY YOUR OVEN AND WANT IT BROUGHT BACK TO 100% CHECK WITH SOME PARTS SELLERS AND GET YOUR NEW PANEL ORDERED. WWW.SEARSPARTDIRECT.COM OR WWW.REPAIRCLINIC.COM
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Touch pad
it requires a professional due to electrical connections
My Amana oven won't work. It shows a error code f6
Error code f6 is an incorrect voltage code. The first thing to do is go to the breaker box and shut the power off to the oven. In some cases there maybe more than 1 breaker controlling the oven, make sure all the power is removed for 5 minutes. After waiting the 5 minutes test the oven if it works all is good, if not you need to gain access to the main board and start checking powers in and out. A lot of the time on a good visual inspection of the wiring and main board you will find the problem due to a melted or burnt spot. I hope this helps.
2/12/2019 7:56:18 AM •
Amana Ovens
Answered
on Feb 12, 2019
I have an Amana ARG7102W P1143347NW gas range that
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
3/19/2018 9:10:37 AM •
Amana Ovens
Answered
on Mar 19, 2018
My amana oven won't start,
To get the bottom of the oven out, you have to reach into the oven way way in back and lift up the bottom of the oven to about forty five degrees. Then pull the bottom back to release the lip on the front. Hope this helps.
3/16/2018 6:17:08 AM •
Amana Ovens
Answered
on Mar 16, 2018
