20 Most Recent
Linksys CIT200 IP Wireless Phone Questions & Answers
Cit 200
The problem has been solved .. . thank you . The hand set had in fact been somehow un registered from the 'Sender ' . I looked up how to register the hand set ( no way would I have thought of holding down the page button on sender for a few seconds , actually until it starts to flash and then you have (via the menu ) to get the hand set into register mode ( you will need your PIN no. if you changed it from factory default ! If you haven't changed it then factory default is ' 0000' ) . . . punch that in to the hand set and then bingo , they are in touch again . . . .
It took HOURS to get it right . . . I tried removing CIT200 and Skype and then reload into computer . . . and I'm not sure now if I have the upgrade or not of CIT200 . . . this morning had the on going problem of phone saying ' unavailable ' and the only way out of this is to reboot my computer . . . that mostly works ! Apart from these BIG niggles the system is clear and good when all configured . . . NOT found the answer to the Niggles yet ! . . . . . ( Why no hard copy of the user manual . . . ridiculous!)
riknvic ..
Linksys CIT 200 for MAC OS
Hi ,nobody know any solution for this DRIVER for MAC OS (Lion) I need to install my CIT200 on a Macboook pro
Cit200 is "connected", but when
Hello.
Try resetting your router, by disconnecting the power and reconnecting. Then, reset the power on the phone.
Hope this resolves your problem.
Installed Windows 7, downloaded CIT200 driver and
from what i know of this phone , it is not compatible with windows 7. I have checked around and your problem is common. you might think to contact linksys directly to see what support they offer for this phone.
Phone disconnected ver cit200
I got the same problem with my CT200 when I updated for Vista. (disconnected) The solution I found is: I avoid logging on to MSN. If the problem still persists I take out the batteries from the phone wait for 10 seconds , reinsert them and the phone works. Hope this helps.
