20 Most Recent ION Audio iTTUSB Turntable Questions & Answers
Stylus arm grams
Start at 1 gram and work your way up. Depending on the cartridge, 1.5 to 3 grams should be sufficient. Don't make it too heavy...use as light a weight as will play and track record properly. After you have set the weight, set the anti-skate knob (or counterweight) to the same force.
3/1/2015 8:18:37 PM • ION Audio iTTUSB... • Answered on Mar 01, 2015
Volume not loud enough when hooked to stereo
It will require a phono preamp...designed for a magnetic phone cartridge that takes into account the RIAA rolloff so you don't lose bass response. A mic preamp won't work properly.
3/1/2015 8:15:00 PM • ION Audio iTTUSB... • Answered on Mar 01, 2015
Drive belt bare hands
Won't usually hurt them, but it's nice to have a non-slipping belt. Just clean it up with a little rubbing alcohol.
3/1/2015 8:13:44 PM • ION Audio iTTUSB... • Answered on Mar 01, 2015
3answers
Need drivers for my ION Audio USB Turntable
Hello USB audio turntable can be found on this site: Driver Update. have a nice day
1/3/2015 11:49:32 PM • ION Audio iTTUSB... • Answered on Jan 03, 2015
Preventing feedback on turntable
Hi, if you are getting feedback then the speakers are likely to be too close to ao facing toward the turntable. Cheers john, Stylus City
12/3/2014 4:11:55 AM • ION Audio iTTUSB... • Answered on Dec 03, 2014
Denondn hs5500 to traktor
Hi Jeib, Here you go. Check out this review and search engine. Ion Ion Audio Ittusb Turntable Reviews Ion Ion Audio Ittusb Turntable... Here is the direct review from a variety of You tube sources with your product in their hands. Take a look. Denondn Hs5500 To Traktor Reviews Denondn Hs5500 To Traktor Product... Since your question is generalized. I still wanted to share this forum www.product.info is the place to go become a member and join in the forum. Go for it. Fare. Well.
7/1/2014 4:55:38 PM • ION Audio iTTUSB... • Answered on Jul 01, 2014
Distorted recording and loud
If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
6/9/2014 12:10:28 AM • ION Audio iTTUSB... • Answered on Jun 09, 2014
Turns too slow
Post the make and model number of the turntable.
5/30/2014 10:45:30 PM • ION Audio iTTUSB... • Answered on May 30, 2014
When using as a stereo interface, it's not playing loudly
It uses a magnetic cartridge so that a stereo amp needs a phono pre-amp to make the signal louder.
3/7/2014 7:48:02 PM • ION Audio iTTUSB... • Answered on Mar 07, 2014
Download software
If you can it will be on the makers of the turntable website.
12/23/2013 8:15:47 PM • ION Audio iTTUSB... • Answered on Dec 23, 2013
Tone arm won't balance
I may have answered this before, but if this has a P Mount tonearm, there are no adjustments to be made. For more information, please visit my website at audoserviceclinic.com. Thank you.
12/9/2013 1:01:58 AM • ION Audio iTTUSB... • Answered on Dec 09, 2013
NO SOUND ON COMPUTER
More often than not the sound control panel of your computer is either muted, switched off, or set to low. Also check your cables.
9/20/2013 11:42:07 PM • ION Audio iTTUSB... • Answered on Sep 20, 2013
I can not hear what is being recorded to my pc
Probably something to do with the control panel of your computer sound system. You might have got one of the controls turned down or switched off.
9/13/2013 4:45:07 PM • ION Audio iTTUSB... • Answered on Sep 13, 2013
0answers
Www ionaudio com ezvc
Sounds like a formating issue. Itunes takes mp4's only. A PC usually works with mp3's or other formats. See if the software you are using offers you to record them into an mp4 format and that should fix it for you. If it will not let you record in mp4, you can download a simple device that can convert them. Honestly I thought ITunes converted them already, may be a setting in ITunes to convert as well! Good Luck, let me know if that isn't the issue.
8/26/2013 11:25:49 AM • ION Audio iTTUSB... • Answered on Aug 26, 2013
2answers
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
2/27/2013 6:52:04 PM • ION Audio iTTUSB... • Answered on Feb 27, 2013
Replacement turntable needles
Look at the cartridge they fit in. That should have a model make and number. Put that into Google and you should find the stylus for it.
2/25/2013 4:49:44 PM • ION Audio iTTUSB... • Answered on Feb 25, 2013
ION Audio iTTUSB Turntable Logo
167 questions posted
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
John
John
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • ION Audio Audio Players & Recorders
Most Popular Question
need drivers ion audio usb turntable
  • Audio Players & Recorders
