20 Most Recent
Logitech X-540 Computer Speakers Questions & Answers
My speakers logitech x-540 doesn't turn on
You should change the fuse, if still does not work, then you should contact Logitech Customer Care for replacement if under warranty.
Thanks and have a nice day
J-
Where is line out jack on tv
Hi there, this will be 1 of 2 outputs. Either a headphone jack or an audio out. Red and white (look for ouput with red and white). From there you will need an adapter. RCA (red and white, no yellow as this is picture) to a 3.5mil female.
Controller has no cabel inside any more
If in a hurry take to a repair shop to see if it can be saved or you need to buy a new one. I would also look on EBAY as can get it fast or Google the number on the remote or unit with "remote".
Signal
Signal source refers to where the signal originates. For a computer, the audio signal's source is the tower itself, so the output from the tower connects to the input to the speaker, completing the connection.
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall itclick start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall then restart your computer and reinstall your soundcard hope this helps
