20 Most Recent
Technics SL-DZ1200 Turntable Questions & Answers
How do i reset my sl-dz1200 it says no audio
hi,
is it shows this when u insert SD card. its not a problem. u have to record tracks using SD audio recording application for pc. only then it will paly the SD audio u have to purchase it separately.
ok
7/13/2013 7:25:10 AM •
Technics...
Answered
on Jul 13, 2013
My scratch pad it sticking
hi is your sl dz first hand or second hand.?did you get it this way??theyr is a big screw under the the display but you'll have to open the deck to screw it.
2/24/2013 1:45:07 AM •
Technics...
Answered
on Feb 24, 2013
Technics SL B210 - New belt, but still "plays up" on 45rpm
Hi, Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the service manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.Ajin
Service manual
2/28/2012 6:50:07 PM •
Technics...
Answered
on Feb 28, 2012
My technicssl-dz1200 sd card keeps
try loading the audio again on your computer. maybe it didn't load properly. also try switching the technics deck off and back on. maybe it is having a bad day and needs to restart.
1/5/2011 2:45:34 PM •
Technics...
Answered
on Jan 05, 2011
Plug in sldz 1200 no power tried another cord
You need to use a ohm meter (you can get one cheap) and find out if the power switch is working. You can also determine with it if the power is getting into the turntable. If the switch is working and power is getting to it, then either the transformer has failed or something is wrong in the power supply section.
12/3/2010 12:31:15 AM •
Technics...
Answered
on Dec 03, 2010
Plays warped
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
8/18/2010 3:54:31 PM •
Technics...
Answered
on Aug 18, 2010
