20 Most Recent
DISH Network ViP 211 DTV Receiver Questions & Answers
My receiver (new) will not turn on? Is there a reset button?
There isn't a reset on these receivers.
If it doesn't show a power light on it, then try disconnecting the power for 30s.
If still no power light
- check the outlet it's connected to
- disconnect all cables from the back of the receiver but power and try again.
- connect the receiver to a different outlet (still with nothing else connected)
if you still don't get a power light on it then the receiver is dead.
Receiver goes off and screen turns green
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you. Please reset the receiver by unplugging it from the wall for 10 seconds. After 10 seconds please plug the receiver back in, allow it to power back on by itself, it will acquire signal and download the guide. If issue persists and you currently have the receiver's power cord connected to a surge protector, please by pass the surge protector and connect the cord directly to a wall outlet. If issue persists after performing this steps please email me at:
[email protected] for further assistance. You can also contact us directly at: 1800-333-3474.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Remote Code
We would be happy to help you with getting your DISH Networkremote to control your LG REAR PRO. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your LG TV; here some of the codes we currently have: 506, 520, 627, 581, 766, and 512.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Got a new hd reciever. can't get hd channels
First make sure your receiver is connected with one of the following.. HDMI (one cord resembling a usb cord but shaped on the ends a little diffrent) or Component wires (this cable is made of 5 wires red and white for sound and red, blue, green for picture) these are the only two ways your receiver will deliver true HD.. Once you've verified that your receiver is connected with one of those methods if you are still not receiving your HD channels you must call your cable provider and tell them there is a code missing from your account.. The cable system has codes that interact with your equipment that tells your receiver what you are allowed or paying to watch in your case the code for HD is missing.. Remember a normal coaxial cable will not deliver true HD from your receiver to your tv. Although that cable does bring the signal to your receiver. There's a good video that can teach you a lot about how this stuff works, might be worth looking into.
Fix your Own cable Save Big Money
How to pair remote with receiver
Brittany Whaley,To address the remote to the receiver, just follow the steps below! Let me know if you have any other questions!Addressing Remote to Receiver:1.) Go to System Info screen.2.) Hold down the SAT button until all mode lights light up.3.) Enter a number between 1 and 15 using the numeric keypad on the remote.4.) Press the pound (#) button. 5.) Once the SAT button blinks three times, press record. 6.) Test remote and see if it works.Tommy FaustDISH Social Media Representative
How do u change the time on the receiver? mine is 1hr behind the actual time. thanks
Brian,I would be happy to help with this. There isn't a specific way to manually update the receiver time. If you just moved service to a new location, the receiver will update automatically.If you're still showing the time off by an hour, let me know and I would be happy to try some steps with you on this.Tommy FaustDISH Social Media Representative
