20 Most Recent Bose Lifestyle 48 Series III System Questions & Answers
2answers
I put a cd into
Here is the manual for this player and it is explained in the begining the disk types and formats that are supported by the player ..If you pay attention this unit will work well with all original dvd , dvd-Rs ..and vcd ..and also audio cd (cd track ) but the mp3 are only played in ISO 9660 format ...
So if the cd is burned into a computer and it has a different format ..it will not be seen by the player ..
I will link the manual ..and also the explain of the iso 9660 format ..
http://www.smarthome.com/manuals/972448w.pdf
http://en.wikipedia.org/wiki/ISO_9660
The idea is to choose this format when you want to make a mp3 cd and be playable into this player ..If the files are wma ..or mp4 or the disk formatting is not the one specified the player will show you the unsupported format error on the display ..
My advice ,if you have a cd with some files you need and it is not seen ..., is to copy them on the computer's HDD ..and than use an audio converter to convert all files to mp3 ...and than use a burning software to burn them in iso9660 format on a cd ..Place them without folder and be sure you chosen the format in case..or ..if you think you can not manage ..burn the files as audio cd ..playable in most cd players ...To do that choose to burn audio cd using windows media player ..add files in a play-list ..(no more than 15 up to 18 files) and than choose to burn them on cd (in windows media player ) They will be converted in tracks first ..and the size will be determined by the time (80 min ) and there will be no more than 18 tracks on a disk ..This way you will be sure it will play on this unit ..
10/14/2012 12:50:42 AM • Bose Lifestyle ... • Answered on Oct 14, 2012
Connecting optical cabel to ps3 and no sound
go to the setting on the ps3 and go to audi select the audio to play through optical
if this does not fix it then
make sure that the bose is in the correct mode to play through optical
1/14/2010 8:43:33 PM • Bose Lifestyle ... • Answered on Jan 14, 2010
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
12/28/2009 3:30:20 PM • Bose Lifestyle ... • Answered on Dec 28, 2009
How to find Bose Acoustimass 10 series iv subwoofer circuit diagram
Contact Bose. Good luck with that.
3/24/2024 8:44:03 AM • Bose Audio... • Answered on Mar 24, 2024
Bose 301 Home Theater machine recorded failed 802 - call Bose. What does it mean please?
How do I solve the 801 and 802 errors on a bose 38 ...
JustAnswer https://www.justanswer.com > Electronics Questions Jul 9, 2010 - We have a Bose Lifestyle 38 in stalled with our Home Theater. ... The bose goes out EVERY 24 hours and displays error: call Bose 801 & 802. 1 answer ยท Top answer: Hi and thanks for using JustAnswer!There are a couple possibilities here.Fi ..
3/22/2024 12:28:12 AM • Bose Audio... • Answered on Mar 22, 2024
Pyle P22-03ABTU stereo receiver.
Question edited for clarity. It is a 'Pyle' not a 'Pile'. It is under warranty. Return it, an internal component has failed probably an electrolytic capacitor. One thing you can try is to disconnect it and move it to another room to discount EMF from something. ..
3/19/2024 5:56:26 PM • Bose Audio... • Answered on Mar 19, 2024
Bose Lifestyle Musik Center 614810, das Display flackert beim einschalten, display bleibt dunkel
Question edited to add SPACES. Question edited to English. In a website where everyone speaks English, you appear to writing in German. We are a North American website, we only speak English here. https://translate.google.ca/ Replace the capacitor on the back of the display board. ..
3/12/2024 4:10:47 AM • Bose Audio... • Answered on Mar 12, 2024
How do I replace rear speaker in 2017 Buick La Crosse, premium trim with Bose system
Here are the speakers https://www.gmpartscenter.net/v-2017-buick-lacrosse--essence--3-6l-v6-gas/body--sound-system No one has documented the job. I would get a local stereo / alarm installer to do it as they have the experience and the trim tools. It would be a fast job for them. https://www.google.com/search?q=2017+Buick+La+Crosse%2C+Bose+system+rear+speaker+replacement ..
1/31/2024 5:22:14 AM • Bose Audio... • Answered on Jan 31, 2024
Bose wave radio doesn't turn on with the remote but one time in 20 to30 times pushing the power button.
You can check with new battery in the remote. Next you point a digital camera, a smartphone should do fine, at the infra red transmitter on the front of the remote and then look on the camera screen if you see the ir light flash different pulses for each button. Infra red light can not be seen but a digital camera shows it really well. Confirm this with another remote. Now you know if the remote functions right. Remotes are available on-line or one can use a universal type remote. The IR receiver is often welded onto the circuit board. This means that it is not right behind the front panel window. It can be obstructed, perhaps by dust or displaced. This is generally speaking.
12/2/2023 6:21:42 AM • Bose Audio... • Answered on Dec 02, 2023
Have Bose Wave CD-3000..Used to have old one with bass & treble. This one has built in equalizer, less base!. How can I hook up additional equalizer to boost the base& highs?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiDrJriwpSCAxWjhIkEHdvbB40QFnoECBUQAQ&url=https%3A%2F%2Fwww.reddit.com%2Fr%2Faudio%2Fcomments%2Flv3vta%2Fbose_wave_music_system_1_bass_adjustment_help%2F&usg=AOvVaw2QM05DPTaM7aZYtdpULoeF&opi=89978449
10/26/2023 8:11:28 PM • Bose Audio... • Answered on Oct 26, 2023
How can I connect a Bose amp to my 1999 sierra all I want to do I know which wire sends signal to the amp so I can run the speakers from the amp and have better sound
1999 gmc/chevy truck ----------------https://www.modifiedlife.com/1999-chevrolet-silverado-audio-wire-guide/
10/22/2023 8:32:24 PM • Bose Audio... • Answered on Oct 22, 2023
Hi, need to get hold of Bose acoustimass 9 user manual
User Manual Link is given below am_multimedia_guide.pdf (bose.com)
9/14/2023 1:17:57 PM • Bose Audio... • Answered on Sep 14, 2023
Bose lifestyle 18 have rapid loud hum when plug to power supply and no led light on the subwoofer.
If you've replaced the LM4766 ICs and the humming sound returned, there could be a few possibilities to consider:
  1. Grounding Issues: Humming sounds in audio systems can often be caused by grounding issues. Ensure that all components are properly grounded and that there are no loose or disconnected grounding connections.
  2. Power Supply Problems: The rapid loud hum could be related to power supply issues. Make sure the power supply is stable and within the correct voltage range. Also, check for any issues with the power cables or connections.
  3. Filter Capacitors: Check the filter capacitors in the power supply section and around the LM4766 ICs. Faulty or aging capacitors can lead to noise issues in audio systems.
  4. Signal Interference: Electrical interference from other devices or cables can sometimes cause humming sounds. Make sure the audio cables are properly shielded and not running too close to power cables.
  5. Speaker Connections: Double-check all speaker connections, ensuring they are secure and properly connected. Loose or damaged speaker wires can lead to noise issues.
  6. Board-Level Problems: There could be other components on the circuit board that are causing the issue. Inspect the circuit board for any signs of damage, burn marks, or soldering issues.
  7. Magnetic Interference: Make sure there are no strong magnetic fields or sources of interference near the system that could be causing the humming sound.
  8. Professional Help: If you've exhausted your troubleshooting efforts and the issue persists, it might be best to seek the assistance of a professional audio technician who has experience with Bose systems. They can perform more advanced diagnostics and repairs.
Remember that working with electronics and audio equipment requires technical expertise and can involve risks, including electrical hazards. If you're not comfortable or experienced with electronic repairs, it's advisable to seek professional assistance to avoid potential damage to the equipment or harm to yourself.
8/5/2023 10:25:16 AM • Bose Audio... • Answered on Aug 05, 2023
Bose Lifestyle  48 Series III System Logo
7 questions posted
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
audio problems connecting ps3 bose
  • Audio Players & Recorders
