20 Most Recent Logitech Quickcam Ultra Vision Webcam Questions & Answers
0answers
When using the ultravision with skyp it sometimes
Check your Audio settings
Typical audio set up
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Still no Luck ?
Visit the logitech website and click on your webcam to check out the support and known issues for your model
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Your cam might have Rightsound which needs to be configured
1/19/2010 12:09:41 PM • Logitech... • Answered on Jan 19, 2010
I can cee myself when i cut onmy mini cam but i
Firstly you have to install the drivers of the webcam on your PC. That you seem to have done as you can see yourself. That means that the camera is being recognized by the PC. Now to get it to work with Yahoo, you have to tell Yahoo to use this camera as default camera while you video talk. To do that you must go to Yahoo Preferences and->Video. There you must specify this camera as the default camera. Save settings. Now you would be able to video talk in Yahoo. To use it with other IMs like Skype etc, the procedure remains the same. Problem in computing is that each and everything has to be told how to do what.
11/19/2009 3:19:59 PM • Logitech... • Answered on Nov 19, 2009
Durint the video conversation my own video doesn't
install window media player latest 1
6/18/2009 11:13:20 AM • Logitech... • Answered on Jun 18, 2009
Echo suppression
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
2/1/2009 9:51:10 PM • Logitech... • Answered on Feb 01, 2009
Quickcam Ultra Vision SE
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
1/14/2009 8:37:38 PM • Logitech... • Answered on Jan 14, 2009
Video call help!!!!!
A. Skype Setup:
B. Yahoo Setup:
NOTE: You audio and video shoud work. Enjoy.
1/14/2009 5:02:16 AM • Logitech... • Answered on Jan 14, 2009
Not connectingmy webcam
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
A. Skype Setup:
B. Yahoo Setup:
1/13/2009 5:50:37 PM • Logitech... • Answered on Jan 13, 2009
Video calling
A. Skype Setup:
B. Yahoo Setup:
1/12/2009 11:02:41 PM • Logitech... • Answered on Jan 12, 2009
2answers
How can i get this
11/21/2008 1:57:55 PM • Logitech... • Answered on Nov 21, 2008
Quickcam Ultra Vision webcam.
Make sure that the correct audio device is selected. It's possible that your application is using the microphone on your laptop (or another device if it's a desktop). Also make sure you have the latest drivers for your operating system from Logitech.
3/2/2008 10:31:04 PM • Logitech... • Answered on Mar 02, 2008
Pls I need a driver software for Logitech V-UD4 P/N:8610560000 S/N:LZA03110563
Hi Joshua, Here's the link for your webcam driver: Logitech Support Hope this helps. Please rate! Thanks, Gary
4/7/2016 4:36:27 PM • Logitech... • Answered on Apr 07, 2016
Skype Gx5 sw1000
1st You download Webcam Driver.Skype Gx5 sw1000After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
2/23/2016 7:29:47 PM • Logitech... • Answered on Feb 23, 2016
Well i got a logitech quickcam communicates stx and it wont work or the software wont work it keeps saying its not compatabile with windows 7 when it worked before with windows 7 what do i need to do
When you re-installed windows 7 did you install the same version or was 32 installed before and you now put in 64?
1/25/2015 3:42:54 AM • Logitech... • Answered on Jan 25, 2015
How do I make a good CCTV system with old webcams and with a Wi Fi router?
hi, why? you just have to select the channels to each camera in local usb and it is ready to show all cameras and able to detect/send and everything... then if you want to remotely see with smart phone (for ex) the easiest way is to install teamviewer with a fixed password and you'll be able to see and do what ever you want on your laptop... the system with a router is also possible but less easy to setup for beginners, you have to add a dyndns option and redirect ports in the router to pass through it to your computer... teamviewer does all the trick !
12/17/2014 6:57:44 AM • Logitech... • Answered on Dec 17, 2014
Is there a Iogitech QuickCam Express Web Cam V-UB2 driver for Windows 7
http://www.logitech.com/en-us/support/3406?crid=405&osid=14&bit=64
9/12/2014 10:25:06 PM • Logitech... • Answered on Sep 12, 2014
Logitech Quickcam Ultra Vision Webcam Logo
Popular Tags
14 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
QuickCam Logitech
  • QuickCam Logitech
Most Popular Question
when using ultravision skyp sometimes
  • Computers & Internet
