20 Most Recent Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Questions & Answers
Can I use the lithium battery adaptor on the old DC12volt dewalt range
No Lion batteries have a different voltage.
10/6/2016 10:44:52 PM • Dewalt DC727KA... • Answered on Oct 06, 2016
0answers
Low power
May have bad motor.
8/14/2015 3:44:11 PM • Dewalt DC727KA... • Answered on Aug 14, 2015
0answers
0answers
3answers
What do i need to know about charging the batterys
Yes, three times. Run them all the way down.Then fully recharge If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
8/20/2012 11:45:10 PM • Dewalt DC727KA... • Answered on Aug 20, 2012
I NEED A CHARGER FOR
good luck I rigged a black and decker from walmart so far it works it has 2 outputs and the 2 pegs on the edge of the batteries take the juice. It saves about 100 bucks cause you can pick up a b&d charger for 25 bucks.
7/8/2012 1:12:10 AM • Dewalt DC727KA... • Answered on Jul 08, 2012
2answers
12v drill/driver not holding charge
sounds like the batt as had its the same prob as i had with mine to give it a bit of life so it will charge get hold of a bigger batt and two bits of wire and connect the + to + and - to - and it should charge but it prob will run down quick
6/20/2011 7:57:11 AM • Dewalt DC727KA... • Answered on Jun 20, 2011
2answers
How do i repair nicad battery
There is no repair, batteries fail, you have to replace them. the bad deal is that you can replace the drill with a new one for about the same $ or less.
6/7/2011 11:01:05 AM • Dewalt DC727KA... • Answered on Jun 07, 2011
I purchased brushes for my
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
4/6/2011 5:27:01 PM • Dewalt DC727KA... • Answered on Apr 06, 2011
Dead power tool battery
You can learn how to bring your Nicad cordless power tool batteries back to life with Battery Resurrection.
A simple procedure will enable your Nicad cordless power tool batteries to again charge in your battery charger and give their full power potential. Works for ALL Nicad batteries including Dewalt, Makita, Craftsman, Skil, Ryobi, Milwaukee, Firestorm, Versapak, Black & &Decker,Coleman,Bosch,Porter Cable, Fein,Hitachi and more.
Battery Resurrection is a registered trademark of Unique Dynamics Inc. Check it out below:
http://www.batteryresurrection.com/
Testimonials from hundreds of users: http://dewalt-battery.uniquedynamics.com
12/8/2010 8:52:27 PM • Dewalt DC727KA... • Answered on Dec 08, 2010
How do I know what torque to set my drill to when
Sorry, there are no rules as to what to set torque to for your job. There are too many variables like thickenss of the wood or drywall or the hardness of the material you're driving into and whether you want the screw to stop above, at or below the surface. The best thing to do is set it low and raise the torque untill it stops when you want it to. Keep in mind if you hit something like a knot it will stop the screw earlier and if you go through a softer spot in the wood it will drive in deeper.
11/2/2010 11:02:55 PM • Dewalt DC727KA... • Answered on Nov 02, 2010
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
6/8/2010 11:30:49 PM • Dewalt DC727KA... • Answered on Jun 08, 2010
Battery charger Delta model CL180C
Hello Alfred. I have that same exact drill and charger. Your charger is shot and there is no fixing it.
You can replace it at http://www.dewaltservicenet.com/
The problem will probably be the cost of a new charger. Good luck with it. Joe
5/4/2010 9:34:38 PM • Dewalt DC727KA... • Answered on May 04, 2010
Drill
Yes, I think this is a good drill, decent price also
1/25/2010 8:52:37 AM • Dewalt DC727KA... • Answered on Jan 25, 2010
I have the charger but i'm back in America and now
You can find one at Radio Shack or another office supply house.
1/5/2010 11:04:51 PM • Dewalt DC727KA... • Answered on Jan 05, 2010
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
26 questions posted
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
charger but back in america now
  • Drills
