20 Most Recent Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Questions & Answers
3answers
Charger is dead (UC12SD). I checked the fuse, it's
Charger is not dead the battery is done in,get a new battery.Led does not light because it does not know it's hooked to a battery.
4/17/2019 8:04:40 AM • Hitachi 12v 3/8"... • Answered on Apr 17, 2019
8answers
Drill battery charger doesn't work
Hi Firemedic13; Most chargers like yours have a fuse inside them. Remove the screws that hold the charger together. The fuse will be on the low voltage side of the transformer. Un-solder and replace it with one of the same value. If the charger is not held together with screws (doubtfull) you will have to carefully cut along the seam where they were glued together. A dremmel tool works good for this. After repairing use some ABS pipe glue to re-seal them together. If the fuse is not blown then the unit will require testing by someone that is proficient with a multimeter. Most times it is the transformer that has fried a wire. If the sides of the transformer have any burnt spots on it then it will be the culprit. Hope this has helped. Best regards; HELP2DIY Please dont forget to rate my answer.
12/30/2016 6:20:30 AM • Hitachi 12v 3/8"... • Answered on Dec 30, 2016
MY CHARGER KEEPS BLOWING FUSES
Primary there is a bridge rectifier that will can have a shorted diode or sometimes a power mosfet that is shortclosed .
2/27/2016 8:26:06 PM • Hitachi 12v 3/8"... • Answered on Feb 27, 2016
My Hitachi UC 18YG charger has flashing (not
I've followed HELP2DIY's advice 4 #3 phillips screws will open the case there are actually 2 fuses 15A glass type which i can see that both wires through the visible glass are intact the rest of the resistors and capacitators & what-not on the circuit board/ breadboard also show no signs of any electrical burns i've also have 2 replacement batteries just to test this charger & still blinking any others found a way to fix this "made in china" product? i also went to AzOn for similar reviews with no real answer but to just buy another one
1/10/2015 10:49:07 PM • Hitachi 12v 3/8"... • Answered on Jan 10, 2015
0answers
3answers
Have a workforce brandname drill/hammer cordless
Replacement batteries for the Workforce 18V cordless drill are available @ 888-315-3080 for $15.00+
I currently have 2 on the way via UPS
Note: This drill is no longer marketed under the WorkForce name (and Home Depot won't help you) but is marketed under several other names including Hillman.
7/28/2010 5:25:08 PM • Hitachi 12v 3/8"... • Answered on Jul 28, 2010
Need to replace chuck
Not entirely familiar with this model but most chucks are secured by a screw inside the chuck. Open the the chuck to its fullest aperture and look inside. There should be a centre screw ... it will be a left hand thread. Remove the screw. Hold the chuck firmly, reverse the drill. The chuck should unscrew from the shaft. Installation is a reversal of the removal procedure.
3/19/2010 2:45:01 PM • Hitachi 12v 3/8"... • Answered on Mar 19, 2010
Have a Plantronics Cordless phone with the
You may have FAILED to check that the polarity matched. Some have the pinpositive, the other the sleeve.
It is UNLIKELY that muchwas damaged beyond the power regulator in the base unit. Should be relatively inexpensive repair.
12/26/2009 8:17:52 PM • Hitachi 12v 3/8"... • Answered on Dec 26, 2009
Hyundie charger dead
try toolking
11/17/2009 1:40:29 PM • Hitachi 12v 3/8"... • Answered on Nov 17, 2009
Can I replace my NiCad battery with a lithium ion?
yes. for the tool, but not the charger.
10/11/2009 12:54:45 AM • Hitachi 12v 3/8"... • Answered on Oct 11, 2009
Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Logo
33 questions posted
Top Hitachi Drills Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Drills
  • Hitachi Drills
Most Popular Question
drill battery charger doesnt work
  • Drills
