20 Most Recent Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Questions & Answers
Batteries leaked into my dewalt laser level
replace it
12/23/2016 11:19:37 PM • Dewalt... • Answered on Dec 23, 2016
How do you remove a stuck battery
with screwdriver
12/23/2016 10:54:11 PM • Dewalt... • Answered on Dec 23, 2016
My laser level wont come on
clean or scratch the contacts if you maybe sometime have had leaking batteries in the compart and inside and clean the white connector plug inside the laser (4 little black torx screws) where the red/black batterypower wire goes to and it is connected downside on the upperprint , becarefull with remounting the cap back for that wire is fully free that little contact must be carefully cleaned with contactspray spray it on something and a little drop is enough. Its generally an easy laser to do a repair in Europe there are different spare parts for to get. I dont know if there can become different spere parts for this model.
11/25/2016 5:32:01 PM • Dewalt... • Answered on Nov 25, 2016
4answers
Dewalt laser dw087 is blinking and cannot self
this unit does not have any replaceable parts, if the unis is covered by warranty, it would be exchange, if not then check with your local servicenter the max rate program to do so.
11/23/2016 7:00:42 PM • Dewalt... • Answered on Nov 23, 2016
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
1/10/2015 3:00:53 PM • Dewalt... • Answered on Jan 10, 2015
How to fix the plug batery
There are spare parts available to repair this but will have to be sent in for repair.
12/17/2014 8:54:22 AM • Dewalt... • Answered on Dec 17, 2014
How to calibrate a dewalt dw089
You have to remove the module from the instrument
12/17/2014 8:52:51 AM • Dewalt... • Answered on Dec 17, 2014
0answers
Dewalt dw073
Be the first to answer 5/31/2014 7:19:02 PM • Dewalt... • Posted on May 31, 2014Be the first to answer
Dewalt laser faults
The lases will not turn on , I ave tried new batters
4/13/2014 9:36:13 AM • Dewalt... • Answered on Apr 13, 2014
0answers
0answers
0answers
Calibrate level
Be the first to answer 11/29/2013 3:17:46 AM • Dewalt... • Posted on Nov 29, 2013Be the first to answer
0answers
0answers
The laser started to come on intermitently and now does not come on at all.
Possible corrosion on battery door or terminals
3/31/2013 2:21:12 PM • Dewalt... • Answered on Mar 31, 2013
Haw i can calibrate
Contact Global Survey Equipment
3/31/2013 2:15:47 PM • Dewalt... • Answered on Mar 31, 2013
0answers
Horizontal line very dull , vertical line normal
if batteries are new then its either a bad connection to diode,cold solder on pcb or simply a blown diode
5/29/2010 2:03:02 AM • Dewalt... • Answered on May 29, 2010
Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
Popular Tags
32 questions posted
Top Dewalt Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Measuring Tools & Sensors
Most Popular Question
check dewalt spinning laser accurate
  • Measuring Tools & Sensors
