20 Most Recent
Black & Decker Compact Power Screwdriver Questions & Answers
The chuck wont tighten
The outer sheath of the chuck turns a thread on the back of the jaws in the chuck and it it is not tightening correctly then the jaw threads have been broken/cracked or the jaws have been stressed out of alignment and are not longer closing in a parallel manner. Best replace the chuck as they are generally not repairable.
Drill
there are no breakdown for the said model
Black decker drill
If the problem is with very small bits 1/16" for example, the chuck could be defective in either design or manufacture. I have had this problem with a cordless model FS1800D. Waiting on a replacement chuck.
Beginner
First of all, congratulations on your new place! I think this box is pretty useful for beginners: http://fadisel.com/Producte.aspx?referencia=1090
Let me know if you need further help, and good luck!
Burke.
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
The blade on my black and decker radial arm saw is locked up. It will not move even by hand.
moved you out of cars to tools
well some have brakes, so hands not cut off, as it spins down.
what is the job here. not told what ACT is being attemped
or if you lost the manual that covers all this.
some blade bolts are LHT , left hand treading so , learn that first
if doing blade swaps.
buy this used and need to learn how to use it?
NO MODEL SAW TOLD at all, nor country told, some are different outside our USA< so not told.
is this the blade spin locked up, NOT TOLD
add more words or tell what your are attempting/
I guessed blade but gee I do no know what's up here
My Black & Decker electric weed-eater only
The bush/bearing behind the trimmer head is probably rusted or worn out and the motor is poling out and creating a short situation. Not much can be done so it may be best to junk it and get a new one.
Want to register a new
get the warranty card out of the box or from the back of the user hand book and fill out all the relevant details and post if off to the manufacturer. Or you may be able to down load from the manufacturers web site a pdf form for the registration.
