Hi
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Daniel
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
Turn oven temperature knob to OFF.
2. Press and hold both arrow pads for approximately 5 seconds.
3. A double digit will display ranging from -35 °F to 35 °F.
4. Immediately, press either:
• to increase oven temperature by 5 °F
• to decrease oven temperature by 5 °F
• When temperature is adjusted to a cooler setting, a minus sign (-) will
display with the offset temperature.
5. When desired temperature change is displayed, release control and
change will be automatically saved after a few seconds. Control will
return to time of day display.
• Offset temperature change will be retained through a power failure.
The complete manual can be downloaded at www.appliancehelponline.com just enter your model # and the manual will be on the left hand side.
60 questions posted
148 Questions
58 Questions
56 Questions
41 Questions
42 Questions
